Originally Posted by k0wtz
francene our 13f scamper is a bouncer what pressure are you running your trailer tires I am going to drop mine to 40lb and see if that helps?
bob
The issue is not the
tires, Bob, it's the rubber torsion
axle. Either it's overrated for the
weight of your trailer, or it's nearing the end of its life cycle. Lowering tire pressure might help a little (subject to the manufacturer's load-inflation chart), but it's not the solution.
I believe Compacts have a leaf spring
axle, so the issues are somewhat different. There is no rubber to age out and become brittle.
