Hunter Compact II table - Fiberglass RV
Old 09-12-2017, 05:49 PM   #1
Trailer: Hunter Compact II
Does anyone have a picture or the dimensions of the table that goes in a hunter Compact II? My 1974 didn't have one or the hardware.
jmb999 is offline   Reply With Quote
Old 09-14-2017, 01:26 PM   #2
Mfrost's Avatar
Trailer: Hunter
Ohio
Compact II Table
Hi, the dimensions of a Compact II table are: 40 1/2" X 29" X 1". There is a bell housing type thing in the center under it that holds the pole up when the table is in use. On the floor is another one for that same pole.
Mfrost is offline   Reply With Quote
Old 09-14-2017, 08:11 PM   #3
Thanks for the information. Can you send a picture of the table in the up position? Seems like it might be a tight fit getting seated.
Old 09-18-2017, 11:00 AM   #4
Mfrost's Avatar
Trailer: Hunter
Ohio
Compact II Table-Upright
Here are a couple pictures of the table in the upright position. It's no different than any boat setup. Yes it's a bit tight but you are not dealing with a 50' RV. It works, I'm not small and I can get in there.
Old 09-18-2017, 08:26 PM   #5
Thanks for sending the pictures. I think I'm going to make my table little smaller so I can get in and sit down easier.
Old 09-18-2017, 08:48 PM   #6
Mfrost's Avatar
Trailer: Hunter
Ohio
Well you have to remember that it swivels so you you can get a pretty big opening. The table has to be this large in order to make the bed. It serves as the platform for the cushions.
Old 09-18-2017, 08:56 PM   #7
As long as the table is the correct width to rest on the side rails, you can play with the length by using a filler to support the bed. Casita does that in their FD and SD models, perhaps others.
I believe our Campster used a filler as well but don't know for sure.
Dave Fish is offline   Reply With Quote
Old 10-06-2017, 02:43 PM   #8
I went ahead and did a table 33 inches and will use the cut off piece to fill in. Does anyone know where to get the metal edge molding? I can't locate any.
Old 10-06-2017, 03:23 PM   #9
On my Campster, they replaced the molding with a standard laminate edge. If you want to be close to original, you probably will prefer the aluminum edge.
I did a quick Google search and found some at a site for Eagle Molding and at Vintage Trailer supply. The examples at Vintage looked more authentic to my memory and also looked easier to bend around the corners. I didn't pay any attention to price.
Adding a front table to a Scamp using the Lagun Swiveling Cockpit Table Mounting Syst gordon2 Modifications, Alterations and Updates 26 08-30-2020 11:12 AM
1973 Compact II by Hunter Darrel Smith Modifications, Alterations and Updates 88 06-18-2020 11:13 AM
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 22 03-17-2014 09:31 PM
Compact/Compact Jr./Hunter class owners JenPB General Chat 21 06-05-2009 02:10 PM
