Hunter Compact Jr has mildew - Fiberglass RV
Old 09-27-2013, 11:38 PM   #1
Trailer: Hunter Compact Junior
I'm new here and haven't been able to find this question answered yet...
My Compact Jr has mildew inside on the quilting. Am I going to need to completely rip it out or can it be saved?
DeniseBrooks is offline   Reply With Quote
Old 09-28-2013, 06:59 AM   #2
Noreen Bradshaw's Avatar
Trailer: 1981 4500 Trillium
Denise, don't give up hope. I don't know what kind of 'Quilting ' is on the walls and ceiling of your little camper but I'm sure someone will know and will be along shortly to answer your question.
Welcome to FGRV!
Noreen Bradshaw is offline   Reply With Quote
Old 09-28-2013, 07:28 AM   #3
Hi Denise, to FiberglassRV, we're glad you're here
Never fear, the quilted ensolite will clean up nicely. Tilex or diluted bleach water (or other) and some gentle scrubbing should do the trick.
You've got a moisture problem going on however. Is anything leaking? During storage, I'd recommend a dehumidifer of some sort. I use Dri-Z-Air Classic. Inside a plastic tub, placed in the sink and checked monthly.
Best of luck!
Old 09-28-2013, 09:51 AM   #4
Hunter interior "quilting" is somewhat like kevlar in strength and is well worth trying to keep. Try reading up on general mildew removal on Google as well as trying suggestions found here. I "think" that there is a "Bomb" that is also effective in killing mold spores than may have crept in behind the stitching.
In as much as mildew does not like sunlight or fresh air, it might be worth the effort to remove the top and leave it open to air for at least a week (weather permitting of course)
As the most common place water gets into the walls is at the windows, it might be a good idea to pull them out for recaulking and leave then out for a while as well to assure a good drying out behind the wall covering.
BTW: DO NOT attempt to just reseal the windows by adding more silicone stuff, it doesn't work and will lead to more leaks & damage in the future. You have to take them out, clean the old putty off and install with new RV putty tape.
And, as it does rain on occasion up your way, as Donna mentioned, keeping a pan of drying agent inside is always a good idea.
Good Luck
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 22 03-17-2014 09:31 PM
Hunter Compact II Pam Garlow Referrals: Molded Fiberglass Trailers 0 07-07-2013 06:37 PM
14' Compact Jr./Hunter Kevin K Referrals: Molded Fiberglass Trailers 2 03-09-2010 09:57 AM
Compact/Compact Jr./Hunter class owners JenPB General Chat 21 06-05-2009 02:10 PM
Hunter 1 (Compact II ?) Legacy Posts Care and Feeding of Molded Fiberglass Trailers 24 05-13-2003 09:14 PM
