hunter1 windows - Fiberglass RV
Old 06-14-2014, 03:54 PM   #1
Trailer: 1974 hunter 1
hunter1 windows
Does anyone know who made the aluminum windows for 1974 hunter 1 and where I can get the glazing strips and other seals for them.
Thanks
Craig
craigb is offline   Reply With Quote
Old 06-14-2014, 08:08 PM   #2
I believe that those are HEHR windows. Here is a link to a supplier.
- RV Windows
Let us know that you find out about spare parts.
Old 06-14-2014, 08:14 PM   #3
Ian G.'s Avatar
Post a picture of what they look like. I am sure parts are available it is just directing you to the correct supplier.
Old 06-16-2014, 07:01 AM   #4
pics of window
Attached are pics of window and glazing strip.
Thanks
Craig
Old 06-16-2014, 07:47 AM   #5
Yep, those are HEHR windows. Did you contact the supplier I mentioned in Post #2? HEHR also has offices in a number of U.S. cities, but I have not had any luck buying parts from them directly.
Old 06-16-2014, 08:52 AM   #6
Hi Bob
Will contact them. Did find glazing strip on vintage trailer supply that looks similar but says its for Hallmark 12.
Hallmark 12 Glazing Strip
Thanks
Craig
Old 06-17-2014, 09:57 AM   #7
Can't seem to find the correct glazing seal on Pellant Enterprises website. Do you have the part number.
Thanks
Craig
Old 06-17-2014, 10:18 AM   #8
No, I don't have a number. Sometimes you have to just bite the bullet, take out the window and send in a sample of the seal you need. I have surgically "snaked" a 1/2 long piece of seal out of a frame without removing the glass, and then taped the opening until I found the seal. You will need some small hook shaped tools.
Old 06-17-2014, 11:44 AM   #9
Trailer: Hunter I
Please let me know what you find, I will need to replace the front window seal on my Hunter I in the near future.
BuddyLee is offline   Reply With Quote
Old 06-18-2014, 10:59 AM   #10
Trailer: Hunter
Need replacement seals too, looking forward to what you may find. Good luck, I will do some Googleing to see if I kind find anything as well....
Skyehunter is offline   Reply With Quote
windows
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
Will Scamp windows fit in a Lil Bigfoot??? Jeff Segel Problem Solving | Owners Helping Owners 1 07-20-2009 02:13 PM
