02-02-2007, 09:58 PM
OK, tomorrow, if all goes well, I will be picking up the new Burro.
I have never towed anything this long before (And I am sure the big stickie folks will think a 17 is puney)
What are all your experiences/learning curves when moving up from a 13 to a 17 or bigger?
Anything that you know now please share, so that it won't suprise me later...
02-02-2007, 11:48 PM
Trailer: 1975 13 ft Trillium
Gina, I'm sure with all your towing experience, you'll have no problems getting used to that extra 1.1 metre, just remember it weighs a titch more so you'll notice that l'il extra bounce and the added length might catch up with you taking corners, highway towing should NOT be an issue... Good Luck with it !!
02-03-2007, 07:19 AM
You'll be fine Gina. I think you'll notice the difference in the width and what you can see behind you, rather than the length. Pulling into driveways, etc. you MAY have to take a wider turn however.
Let us know how it goes and still patiently waiting for pics.
02-03-2007, 09:38 AM
Trailer: Bigfoot 21.5 ft (25B21RB)
Yeah, what Donna said. When my sister got her wide-body Burro, seeing down the side of it became limited. I just experienced the same thing moving from the Casita to the Bigfoot. Going down the road it's no big deal, but when backing up it is. I am planning to get some extended mirrors for my truck now. Congrats on your new purchase, sound great! Dave
02-03-2007, 09:47 AM
Well, the biggest thing I am afraid of is:
folks on my street are rude parkers. Last nite, for example, I had to squeak by two cars parked on opposite sides of the street with almost zero clearance.. in a Jeep Liberty! (They are realtively skinny)
I am not sure if there is that road block that I can back the thing out.
Next is that I have to parallel park in my driveway. It runs the width of my property, not lengthwise. I got good at whipping the 13 into it sideways, but that won't work for this one, it's too long and the tongue would be in the road.
02-03-2007, 09:57 AM
Trailer: Boler Honey
Gina,
I notice you said you "got good" at parking the 13'. I am sure you will also get good at putting the 17' in the driveway...that's what its all about, experience! You have all the good skills. I wish I could give you some advice based on experience. But having no experience with a 17' I'll just wish you luck and give you encouragement!
02-03-2007, 10:18 AM
Trailer: Boler 1984
Take it slow !
Take it Easy!
If you can handle a short trailer then A longer one will be a snap. A short trailer with a shorter wheelbase turns quicker and so mistakes are bigger.
" Don't forget we're pullen for ya. We're all in this together"..... Red Green
02-03-2007, 10:34 AM
Trailer: Trillium 4500
It might be a good idea to practice emergency manuvers with any new vehicle or trailer. Try a hard stop and lane change before you get into an emergency situation, it will give you confidence in your abilities and your rig capabilities. With more weight comes greater stopping distances. Have fun! Dave.
PS. Don't have to much caffeine the day you pick up the trailer!
02-03-2007, 10:38 AM
LOL!
It's today and I am already on my 3rd cup!
02-03-2007, 10:53 AM
...you <strike>MAY</strike> WILL have to take a wider turn however.
It will be easier to back up [b] IF you have plenty of room, because the reaction will not be as quick. BUT if space is tight, it will feel like trying to parallel park the Queen Mary. This might be one instance where a short tow vehicle could be an asset.
02-03-2007, 01:53 PM
I have never towed a 13' egg, but have have towed a smaller tent trailer, and an even smaller utility trailer, as well as a bigger (than my B1700) stickie travel trailer and longer and wider flat-deck cargo and car-carrying trailers.
I find the transition generally troublefree, although like Donna I find the width more a concern than length. The longer trailers are more stable, which can make backing up less frustrating if you have room. I have only really parallel parked my Boler a couple of times, and suspect that if you don't get it on the first try, pulling right out and going around for another pass will probably be more successful than endless jockeying back and forth.
The corner cutting problem is a combination of trailer length (from coupler to axle) and trailer track width. That tent trailer which I rented had such narrow track it essentially followed the inside van wheel in typical intersection turns. Since both length and track are presumably significantly increased from 13' narrow-body Burro to 17' wide-body, this is certainly something to be aware of. I don't really think of this as swinging wider, but rather turning later, remembering that the trailer turns as soon as you do, but isn't as far down the road. I know that's not exactly how the geometry works, but thinking of it that way works for me.
For clearance between other vehicles, aim down the middle (without obsessing about watching each side) and you might be surprised how easy it is.
For backing, I think seeing where the far corner of the trailer might be is the biggest issue. If I had to regularly back into a really tight space, I'd look seriously at those back-up cameras, but for a driveway it might be good enough just to get it in place once, then note where the front of the trailer is versus some landmark, as a reference point for the next time.
It's worth noting that the bigger trailer is heavier so more allowance must be made for acceleration; however, perhaps the Liberty/17' combination will perform similarly to the Element/13' combination?
02-03-2007, 05:44 PM
For really precise placement of a trailer, esp snaking it around curves into tight spaces, a front-mounted receiver hitch will really do the job.
Also, one of those trailer dolly gizmos from Northern Tools with a ball on it to manually move the trailer on level ground might be handy.
02-03-2007, 06:20 PM
Trailer: Casita 17 ft 2004
Gina, I hope all went well for you. It did for me. I found pulling and backing the 17' Casita for the first time today, was no big deal. Now with that said, I spent the entire drive up there with a herd of elephants flapping their ears in my stomach. I was so scared. My co-pilot, Bob, was a familiar face from last year's rally and was great. His wife, Judy, was also at the rally. I got a great educations with all the "this thingy" does this, and showing me the ropes.
It is great to have FGRV family!
02-03-2007, 06:24 PM
The front-mounted receiver (e.g. the FMR's from Reese) idea makes sense to me. While I've never had a chance to use one, I can picture how it would work well for parallel parking. You would drive the ball to where it needs to go, and the tug just follows along... which is fine as long as the FMR helps you to do it one pass.
A couple problems might be that these are generally for body-on-frame vehicles (for ease of mounting), and that for some rigs the hitch load which is okay for the back might be too much for the front of the tug. While Reese does show FMRs for various Jeeps - even including some unibody models - it does not show one for the Liberty (it is a Liberty, right Gina?).
The installation instructions for the Cherokee version (Liberty predecessor) show that it attaches at the swaybar bracket mounting points plus a couple more holes drilled in the frame... and has only a 300 lb weight limit, which is just enough for my Boler, and not enough for some Casitas and most recent Bigfoot models. Perhaps those for larger SUVs and full-frame trucks have more capacity, but it's something to keep in mind. I assume that the mounting is the strength limitation, rather than the receiver frame.
I just bought one of those non-powered trailer dollies, because it was on sale and so it was a good time for something I'm likely to need someday. Mine came from Princess Auto, which I think is a lot like Northern Tool. I have not tried moving the Boler with it (haven't even assembled it), because I'm not really up for trying to clear the packed and crusted snow which is now about up to frame level (which starts a foot off the ground in a B1700).
Anyway, I think with a widebody Burro or 17' Boler that level ground will be important for hand manipulation to work for most of us, and this is one case where a person's size does matter. Now a powered dolly... that's another matter, and I agree that would be the ticket. That or a set of caravan movers from Europe, like Lex told us about a while ago.
02-03-2007, 08:27 PM
I move my 16' Scamp around on level asphalt with a manual trailer dolly...I love it! But trust me, I don't see Gina moving the Burro with it....she's a petite lady and I don't think she could even move the 13' with it
02-03-2007, 09:19 PM
Trailer: Burro 17 ft Widebody
I use a "Powercaster." No choice, just quite expensive. But it was that or no Burro. Works really well, but the incline it will conquer depends on the proportion of weight on the tongue. There have been times when I've had two people stanting on the tongue for traction when the pavements was wet.
02-03-2007, 10:36 PM
I use a dolly around here to move the trailers and with the 17' up an uphill grade on asphalt, the dolly wheels lift off the driveway....I may as well have a longer hitch with a handle on it....also a problem with the 13' is that because I have a caster wheel on it, I can`t leave it sitting on the part of the driveway that`s sloped as the trailer wants to roll down hill.....of course with the 13, I really don`t need a dolly as I can move it around on the trailer wheels and the hitch caster wheel, like a tricycle....looked at the powered wheels at Princess Auto but thought that it would be a waste of money for me..,..around here I can also drop either trailer onto the garden tractor to move them around on the lawn,etc. ....of course now nothing is on the move with the snow and ambient temps near -40 ....brrrr ....never mind the wind chills!!! ... ..Benny
02-03-2007, 11:56 PM
It was not quite as traumatic or dramatic as I had feared
I actually came home along a hiway I most frequently tow the 13 on, so there were no suprises in that aspect. It just followed me, and the extra turning space seemed intuitive.
I recently had to drive a 24 foot uhaul with a 10 foot car dolly on it that I could never see except when turning, and I did OK with that.
The width did not seem a probelm. I noted it is wider than the 13, but split down the middle, I could still see the lane lines with plenty of space at either.. and with my regular Jeep Mirrors.
The trailer came with towing mirrors, and they were clipped on and adjusted, but I did not find them an additional help over my stock ones. Talk to me when backing tho!
It DOES back easier. It is temporarily sitting on some property a few blocks from here where there is a space cleared for it, but it involves backing uphill and around a motorhome, and I didn't think it prudent to make that attempt in the dark on my first outing. I will try again in the morning.
It did seem more stable than the Element 13 combo, more solid is the best way I can describe it. The Jeep did great.
02-04-2007, 01:06 AM
Trailer: Bigfoot 25 ft / Dodge 3500HD 4X4 Jake Brake
Good for you. We are all proud of you.
I was afraid I was going to have to get the monkey out.
02-04-2007, 03:43 AM
Trailer: 1974 Ventura
For a long time I have been pondering the use of a wheel apparatus on the front jack for manuevering. It was mentioned the use of a dolly - limit 600 lbs. There was also mentioned a swivel trailer jack - 750 lbs. I assume that that is the weight on the trailer hitch. My question is I really don't know what my hitch weight is, my trailer is 1500 lbs. (gross trailer weight). The info is on my spec sheet.
As long as it's not uphill, how strong does one have to be to push this trailer around by myself. I know, I know backing it up to park it takes practice, to make it perfect. The stress exacerbates especially when there is an audience of other campers watching, it's always a man. It's not that I am too proud, but would like to handle this trailer on my own. (there isn't always someone around either). It was very costly on my trip to the Yukon paying for those huge sites that were pull through. Kinda funny when we had monster motorhomes and enormus TT. Thanks for the ear .
