I am woman Hear me ROAR!!! - Fiberglass RV
Old 02-24-2007, 10:03 PM   #1
Gina D.'s Avatar
That'll teach THAT crappy thing to mess with me.
Leak is all fixed. And I didn't even need to wear pants that showed the upper features of my posterior!
Hah!
The fitting that Walts sold me was all wrong, it didn't fit over the hose.. but.. I stopped at Giant RV during the week and bought every fitting that even came close to what I have. They had toilets I could try them on too.
It turned out to be the same fitting used on water pumps. I used my idea of putting a hose clamp over the nut to give me something to push on with the needle nose pliers when I turned it. Worked great!
I AM going to put a shut off valve in the line, however. If it doesn't hold, I can shut the supply to the bog off and still use everything else. I can even flush with other water in an emergency.
*Blows smoke away from tip of needle nose and walks off into sunset...*
Old 02-24-2007, 10:09 PM   #2
james kent's Avatar
Trailer: Boler 1984
Not a roar.
That's the sound of the flush
When she pulls the chain, gang
Old 02-24-2007, 10:20 PM   #3
Gina,
So persistance pays off again Your idea of adding a shut-off, like at home, is just as wise in a TT.
She who blows smoke..., has a native American ring to it , but I'm not so sure of "She who blows smoke and tows McMansion".
OK, heading for the room with the new drywall to hide from the monkeys,
Kurt & Ann K.
Old 02-24-2007, 11:09 PM   #4
Trailer: Burro 17 ft Widebody
Good work, Gina!
The plumbing system in mine (and probably in yours) is indeed made with Flair-It fittings, I just looked it up. I used to slip the tubing onto the little dears after using a stove lighter to soften it up. But, apparently that is a no-no. They say to use a hair dryer/heat gun to do that safely.
I am on my second toilet valve.It does not always shut off by itself at times so I just pull up a little on the lever. The shut-off idea is a good one and I will do that too at the same time I do the inspection hatch mod.
I can just see us halfway up the Alcan having to deal with this aggravation. Not going to happen. Now I have to go to work on the noisy water pump, etc. Isn't it nice that there is always something to do on these things?!
Old 02-25-2007, 06:32 AM   #5
Trailer:
Leak is all fixed.
I fear that these are two contradictory statements.
Andrew
Old 02-25-2007, 08:43 AM   #6
Trailer: 2007 17 ft Casita Spirit Deluxe
Isolation valves are a smart way to go. If a problem arises, at least the rest of your rig can operate without a complete shutdown.
Gary Lynch is offline   Reply With Quote
Old 02-25-2007, 08:57 AM   #7
Taylor Kissinger's Avatar
Trailer: 19 ft Scamp (Egg Salad Annie)
<Way Cool> {Can Do Woman}(She who must be obeyed)
Taylor Kissinger is offline   Reply With Quote
Old 02-25-2007, 03:15 PM   #8
Trailer: Casita 17 ft Spirit Deluxe / Infiniti SUV
Oh, that's what my greatgrandkids mean when they say they're finally "potty trained", huh?
George Cathcart is offline   Reply With Quote
Old 02-26-2007, 09:56 PM   #9
Christi W's Avatar
Trailer: 1987 17 ft Burro
YEA GINA -
We were all waiting to see if you would win out. I think it makes us all feel we can do it if we keep at it. Glad you won!!
Christi W is offline   Reply With Quote
Old 03-02-2007, 12:52 AM   #10
This is what all the fuss has been about. With Gina's heroic efforts to inspire and my own traumatic memories prodding me I had to make an access panel to be able to do what she did plus replace the valve should it go belly up.
The access from the bathroom is just about impossible, at least to replace the valve.
All the pieces are screwed in and can be removed from the outside. I saved the inner and the outer piece of fiberglass and just put them back in the frame, but we are thinking of using this as a rotating picture frame. To that end the screws are actually S.S. machine screws going into threaded inserts so they will not wear and go loose on me.
The problem is that it is near the floor, so the possiblities are limited: picture of the dog, a matching maple panel, a mirror (if the dog becomes even more vain), pictures of a steak, a cat, or of the mailman. That's cruel.
Old 03-02-2007, 07:56 AM   #11
Per,
Nice and clean. Another example of "why didn't the factory do that?" type jobs.
Kurt & Ann K.
Old 03-02-2007, 08:33 AM   #12
Gina D.'s Avatar
wel, if you need a crutch.....
Old 03-02-2007, 08:43 AM   #13
CindyL's Avatar
Trailer: 16 ft U-Haul VT
Gina and Per:
Non toilet related question here - what is the inside height of your longer and newer Burros? Are they as tall inside as my '78 13' model? My 6' hubby can stand in our '78. Is this possible in your trailers?
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 03-02-2007, 08:47 AM   #14
Gina D.'s Avatar
He can stand and then some.
Possibly play soccer, or practice on his riding lawnmower...
Old 03-02-2007, 09:12 AM   #15
Cindy:
73" from carpeting to the center vinyl strip, marginally more to the fiberglass ceiling near it. He could stand, but no room for a riding lawnmower.
Old 03-02-2007, 09:12 AM   #16
Gina D.'s Avatar
Per, if you really want a correct image there, you need an image of two bloody hands, a bent pair of needle nose and two dogs noses.
Add spraying water and a text bubble with " ^$&^#%@*$#%#&% " in it.
Old 03-02-2007, 12:26 PM   #17
My experience tells me that you are absolutely not "embroidering" that image. If you should be in these here parts someday and haven't already prevented this from happening again just stop by and let me perform surgery on yours. I just can't stand seeing grown women in pain. Once is enough.
Old 03-02-2007, 01:30 PM   #18
CindyL's Avatar
No riding lawnmower anyway.
Cindy
Old 03-02-2007, 10:49 PM   #19
Gina D.'s Avatar
What about a soccer ball?
Per, leave the white inside the frame. It will be a great conversation piece.
I have a frame in mine. Nothing in it. It looks good, and...
folks ask...
Old 03-04-2007, 09:16 AM   #20
Send a message via MSN to christineb
I must add my 2 cents worth here, as we just had to fit a new gasket on our "Loo" (for the Brits among us) I don't know how you're "supposed" to do it, but I ended up with my hand down inside the toilet, through the thingy that opens and shuts with the flush.........so that the screws wouldn't fall into the holding tank! I have long fingers and smallish hands, so it worked, but I'm pretty sure there must be a better way? My husband is big boned with giant hands and just could not have done it, not to mention the knee replacement and curling up in that little space. Great incentive to stay flexible and not get too fat.............
Christine
christineb is offline   Reply With Quote
The perfect man and woman Christi V. Jokes, Stories & Tall Tales 10 12-08-2008 05:12 PM
Feel like a woman Al & Donna Jokes, Stories & Tall Tales 0 08-06-2007 07:23 AM
A Woman's Prayer Benita Jokes, Stories & Tall Tales 1 10-11-2006 11:27 PM
Did you hear about the Horse.. Legacy Posts Jokes, Stories & Tall Tales 1 09-21-2002 03:16 AM
