I can't find the VIN - Fiberglass RV
Old 04-25-2007, 07:40 PM   #1
Trailer: Acorn 13 ft (1979)
I feel like an idiot, but I cann't find the VIN plate on my Scamp (Acorn). I need to get the VIN inspected to get tags so I can finally get out camping. Help, please.
Matt
mwinslow is offline   Reply With Quote
Old 04-25-2007, 08:10 PM   #2
Trailer: Scamp 13 ft
There is no plate to be found. Scamp uses a metal stamp to put the numbers/letters on the inside of the "A" frame just behind the coupler. You may have to scrape away some paint and or rust there and they will probably still be faint at best. Good luck and happy camping!
Chris L. is offline   Reply With Quote
Old 04-25-2007, 08:26 PM   #3
Trailer: 1981 Scamp 13 ft
All i was able to find on my 81 Scamp was a barely legible paper label on the inside of the right frame tube just behind the coupler,if there is anything stamped there i didnt see it. The number was E-1-XXXX.Yours being an Acorn is probably about the same vintage so may be similar.I got some stamps and stamped it clearly on the frame tube just inboard of the welded on jack mounting plate as that paper label may not be readable the next time someone needs those numbers. Don
Don Fowler is offline   Reply With Quote
Old 04-25-2007, 08:54 PM   #4
Dan Meyer's Avatar
Hi Matt
Go to my web site - http://scamp.n0kfb.org/ - click on "Scamp VIN decoding" and click on ". Click for a picture of a typical VIN and label "
-- Dan Meyer
Old 04-26-2007, 02:40 PM   #5
Pete Dumbleton's Avatar
For folks searching, it should be noted that most models of Scamps (and Bolers?) and other eggs had the serial numbers stamped into the metal on TOP of the curbside A-frame member, with the paper label stuck to the inside of the frame. There may be layers of paint over the stamped numbers and a flashlight held parallel to the A-frame top may also help in finding and reading them.
license, registration, title, vin
Where to find Rat Fur?! Mike Whitney Care and Feeding of Molded Fiberglass Trailers 1 02-18-2010 11:51 PM
HELP to find the right trailer davidhopkins Wanted: Molded Fiberglass Travel Trailers 3 04-21-2006 06:16 PM
Help me find Lynn Musgrave General Chat 23 02-01-2006 07:56 PM
Ice Box - Where to find? Sandy Gilpin Care and Feeding of Molded Fiberglass Trailers 10 12-09-2005 09:26 PM
