I need a better step - Fiberglass RV
Old 07-22-2013, 06:38 PM   #1
Bobbie Mayer's Avatar
The little green folding step is about 9 inches tall. Besides being too short, esp. if I'm on a slope (I'm on a slight slope in the pic) it moves too easily. I'd like something a little taller (or two steps) that I could anchor to the back bumper. Not mounted, necessarily, just to be able to keep it in place when it is in use. Any suggestions?
Bobbie (and Jack.)
Old 07-23-2013, 10:22 AM   #2
Trailer: 1984 UHaul CT13
Bobbie, You might try the aerobic (sp) step-up things, that is what I use. Just saw some on craigslist for $15 each. It works great as it is light weight and easy to store.
keekers is offline   Reply With Quote
Old 07-23-2013, 10:37 AM   #3
Here's one solution With a bit of ingenuity something could be fashioned to attach to back your trailer which would keep it stable.
And another This is a bit expensive, the main advantage is won't slip and very sturdy,
Yet another This is the one I use. It's very stable and doesn't move once in place. Yet it folds up and travels well.
In something like this I think stability is probably the most important thing, particularly as we go older and falls become major issues.
Old 07-23-2013, 11:16 AM   #4
I used to have an exercise step but they get heavier as they get higher and harder to store. Byron, the one you use looks good, but it's too short. I have a nine inch high step now, it only goes to 8 inches. And the two-step one may be too tall- though i suppose I could carry both and use the 9 inch if we are low and the two-step (at 17 iches) if high.
I agree with you that stability is essential- but right now I've got a 1 foot drop to the top of the stool. That's a bit too much. Maybe a ten inch stool would work if I can find one.
Old 07-23-2013, 11:17 AM   #5
Steve L.'s Avatar
I've used one of those folding steps like you have for years but it is a small target to hit. Not cheap but I have been really pleased with the step shown in Bryon's second link. It's a big target, nonskid and I use the adjustable leg feature to level it and keep it from rocking. (I like a level target for that first step outside and the ground just outside the step isn't always level.)
Old 07-23-2013, 11:17 AM   #6
Gilda's Avatar
Trailer: 2011 Scamp 13'
Bobbie,
You might want to add a very strong vertical grab bar to the side of your rig too.
The Gleeful Glamper
Gilda (Jill-da)
Old 07-23-2013, 11:19 AM   #7
Gilda's Avatar
Here's an interesting solution. RV Manual Pull-Out Step - Single Stromberg Carlson Enclosed Trailer Parts SM-24-10 Personally, I have no idea how to install it or if it will be practical in your situation.
The Gleeful Glamper
Gilda (Jill-da)
Old 07-23-2013, 11:22 AM   #8
Gilda's Avatar
Here's a possible handrail Lend - A - Hand Folding Rv Handrail, Satin Metal - 422951, Steps Ladders at Sportsman's Guide.
The Gleeful Glamper
Gilda (Jill-da)
Old 07-23-2013, 11:29 AM   #9
The door frame works fine as a handrail. A larger target step is a good point- I like the adjustable leg one. Before the next trip I go by Camping World so maybe I'll check out what's available. Or look for a two-step stool that is a little shorter, say, 7 and 14 inches.
Old 07-23-2013, 11:47 AM   #10
Here's one that's a little bulky but the heights look about right.
Old 07-23-2013, 11:50 AM   #11
I've seen those- huge. Won't work, as it would take too much room in the trailer or car. (Great steps, though.)
I'll figure out what the tallest of the platform types is- that looks to be the best bet and much less likely to be knocked out of place.
Old 07-23-2013, 12:56 PM   #12
I have one of these folding 2 steps and it works OK it says rated for 300 lbs but I wouldn push it that far.
RV Folding 2 Step E-Z Foldz Stool Beige 105-4BG
Old 07-23-2013, 01:55 PM   #13
hillary's Avatar
Trailer: 2008 Bigfoot 25B17.5G
What about this? It's $34 and a step stool and grip bar in one, so you'd have to put the grip bar to the left of the door to open and close it without issue: Amazon.com: Duro-Med Foot Stool with Support Handle, Silver/Black: Health & Personal Care
I'm having the same problem and trying to decide if a folding one is worth the extra expense! Our trailer came with a wood one the PO made, and it's step surface area is just smaller than I'd like, and it's a little short.
Hillary & Jeff
Camping with the sighthound variety pack and leaving 4 cats at home
hillary is offline   Reply With Quote
Old 07-23-2013, 02:01 PM   #14
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Why not use actual rv steps? It looks like you have plenty of ground clearance.
Old 07-23-2013, 02:13 PM   #15
Trailer: Hunter 1
I love my exercise steps, $5 at Goodwill, wider than the trailer door so very little chance of missing them as I back out of my Hunter to avoid hitting the door sill. Also wide/big enough to put stuff on when loading or unloading the trailer. The rubber is non-skid and it's easy to level them with 2x4 if needed. They don't weigh much and do a good job of filling the floor to keep the ice chest and other heavy articles in front of the axle while going down the road.
Loyce is offline   Reply With Quote
Old 07-23-2013, 02:34 PM   #16
How tall, Loyce? The only tall ones I saw were done by stacking stuff and were very heavy.
Old 07-23-2013, 02:35 PM   #17
Actual RV steps never seem all that sturdy- and I'm not sure how they'd attach on just a two inch square bumper.
Old 07-23-2013, 02:55 PM   #18
BAMA & Pachyderm Posse's Avatar
Trailer: 2006 17 ft Casita
Bobbie (and Jack.)
Attachment 62245
see if you think you might like this I think I have one used one left
HERSCHEL AKA BAMA
BAMA & Pachyderm Posse is offline   Reply With Quote
Old 07-23-2013, 03:07 PM   #19
Trailer: Hunter 1
Exercise steps.
It can be 8", 6" or 4" tall. There are 3 sections that stack together. It is 26" wide, 16" deep and they weighed 11 1/2 lbs. I'll post a pic of them to your FB posting about it. I think I'll be painting them eventually. Loved the price.
Old 07-23-2013, 03:36 PM   #20
I can't see how the folding steps are mounted. I did see some like that online but minimum height was 18 inches and I think sometimes my bumper is lower than that.
I think what I want is either two steps or 10-11 inches high.
Anybody add a step on a Scamp? iplumb Problem Solving | Owners Helping Owners 10 02-07-2012 07:48 AM
1st step taken... now what? David Swinnard Problem Solving | Owners Helping Owners 16 04-17-2008 05:42 AM
Door Step Legacy Posts Problem Solving | Owners Helping Owners 13 05-02-2007 10:34 PM
We take the step Dennis & Bonnie Anderson General Chat 1 03-17-2006 03:38 PM
