I need a better step - Fiberglass RV
Old 07-22-2013, 06:38 PM   #1
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
The little green folding step is about 9 inches tall. Besides being too short, esp. if I'm on a slope (I'm on a slight slope in the pic) it moves too easily. I'd like something a little taller (or two steps) that I could anchor to the back bumper. Not mounted, necessarily, just to be able to keep it in place when it is in use. Any suggestions?
Bobbie (and Jack.)
Old 07-23-2013, 10:22 AM   #2
Trailer: 1984 UHaul CT13
Bobbie, You might try the aerobic (sp) step-up things, that is what I use. Just saw some on craigslist for $15 each. It works great as it is light weight and easy to store.
keekers is offline   Reply With Quote
Old 07-23-2013, 10:37 AM   #3
Here's one solution With a bit of ingenuity something could be fashioned to attach to back your trailer which would keep it stable.
And another This is a bit expensive, the main advantage is won't slip and very sturdy,
Yet another This is the one I use. It's very stable and doesn't move once in place. Yet it folds up and travels well.
In something like this I think stability is probably the most important thing, particularly as we go older and falls become major issues.
Old 07-23-2013, 11:16 AM   #4
I used to have an exercise step but they get heavier as they get higher and harder to store. Byron, the one you use looks good, but it's too short. I have a nine inch high step now, it only goes to 8 inches. And the two-step one may be too tall- though i suppose I could carry both and use the 9 inch if we are low and the two-step (at 17 iches) if high.
I agree with you that stability is essential- but right now I've got a 1 foot drop to the top of the stool. That's a bit too much. Maybe a ten inch stool would work if I can find one.
Old 07-23-2013, 11:17 AM   #5
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I've used one of those folding steps like you have for years but it is a small target to hit. Not cheap but I have been really pleased with the step shown in Bryon's second link. It's a big target, nonskid and I use the adjustable leg feature to level it and keep it from rocking. (I like a level target for that first step outside and the ground just outside the step isn't always level.)
Old 07-23-2013, 11:17 AM   #6
Gilda's Avatar
Trailer: 2011 Scamp 13'
Bobbie,
You might want to add a very strong vertical grab bar to the side of your rig too.
The Gleeful Glamper
Gilda (Jill-da)
Old 07-23-2013, 11:19 AM   #7
Gilda's Avatar
Here's an interesting solution. RV Manual Pull-Out Step - Single Stromberg Carlson Enclosed Trailer Parts SM-24-10 Personally, I have no idea how to install it or if it will be practical in your situation.
The Gleeful Glamper
Gilda (Jill-da)
Old 07-23-2013, 11:22 AM   #8
Gilda's Avatar
Here's a possible handrail Lend - A - Hand Folding Rv Handrail, Satin Metal - 422951, Steps Ladders at Sportsman's Guide.
The Gleeful Glamper
Gilda (Jill-da)
Old 07-23-2013, 11:29 AM   #9
The door frame works fine as a handrail. A larger target step is a good point- I like the adjustable leg one. Before the next trip I go by Camping World so maybe I'll check out what's available. Or look for a two-step stool that is a little shorter, say, 7 and 14 inches.
Old 07-23-2013, 11:47 AM   #10
Here's one that's a little bulky but the heights look about right.
Old 07-23-2013, 11:50 AM   #11
I've seen those- huge. Won't work, as it would take too much room in the trailer or car. (Great steps, though.)
I'll figure out what the tallest of the platform types is- that looks to be the best bet and much less likely to be knocked out of place.
Old 07-23-2013, 12:56 PM   #12
I have one of these folding 2 steps and it works OK it says rated for 300 lbs but I wouldn push it that far.
RV Folding 2 Step E-Z Foldz Stool Beige 105-4BG
Old 07-23-2013, 01:55 PM   #13
hillary's Avatar
Trailer: 2008 Bigfoot 25B17.5G
What about this? It's $34 and a step stool and grip bar in one, so you'd have to put the grip bar to the left of the door to open and close it without issue: Amazon.com: Duro-Med Foot Stool with Support Handle, Silver/Black: Health & Personal Care
I'm having the same problem and trying to decide if a folding one is worth the extra expense! Our trailer came with a wood one the PO made, and it's step surface area is just smaller than I'd like, and it's a little short.
Hillary & Jeff
Camping with the sighthound variety pack and leaving 4 cats at home
hillary is offline   Reply With Quote
Old 07-23-2013, 02:01 PM   #14
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Why not use actual rv steps? It looks like you have plenty of ground clearance.
Anybody add a step on a Scamp? iplumb Problem Solving | Owners Helping Owners 10 02-07-2012 06:48 AM
1st step taken... now what? David Swinnard Problem Solving | Owners Helping Owners 16 04-17-2008 05:42 AM
Door Step Legacy Posts Problem Solving | Owners Helping Owners 13 05-02-2007 10:34 PM
We take the step Dennis & Bonnie Anderson General Chat 1 03-17-2006 02:38 PM
