I Need a Vent - Fiberglass RV
Old 07-25-2018, 12:28 PM   #1
Trailer: ParkLiner
Virginia
I Need a Vent
I have an older Parkliner that has the air conditioner under the seat.
There is a piece of fiberglass that separates the air conditioner area from the leg area under the table. I want to cut a hole in the fiberglass and put a vent in, so that air can be pulled into the ac.
Can someone tell me what this vent is called so I can buy one? I imagine I can get it at a big box store, but would like to check to see who has it in stock.
Thanks
Huck is offline   Reply With Quote
Old 07-25-2018, 12:48 PM   #2
Trailer: ParkLiner
Virginia
I think maybe I found what I need. It can be opened and closed which I think would be good. It's just a sidewall/ceiling white register. It's meant for the air to flow out and I plan on using it to draw air in.
I'm open to a better idea.
Old 07-25-2018, 01:04 PM   #3
Trailer: 2014 Escape 21, Lil Joe
The condenser intake air should be drawn from the outside. There should be a baffle to get the outside air to the A/C condenser. The evaporator air (inside air) is drawn from and exhausted to the inside of the trailer usually in the front of the A/C. If you are trying to draw inside air for the condenser you will be pumping conditioned air outside.
Eddie
Old 07-25-2018, 01:16 PM   #4
Trailer: ParkLiner
Virginia
Eddie
The design didn't work, which is why they now roof mount the ac. I'm just trying to figure out how to get it to cool better than it does now. It's wedged in with no air space on either side or on the top. There is a baffle, but it only separates the exhaust from the rest of the ac.
Here is a picture that shows the problem. The ac is crammed in this hole under the seat until the rear of ac is pushed through the divider creating a hot area behind it. There is no obvious way to get air to the side vents from the outside.
They went to a lot of trouble to make a hole in the floor and have it open under the trailer and covered with a screen, but since there are no vents in the bottom of the ac, very little air can flow from under the ac to the side vents.
Old 07-25-2018, 01:33 PM   #5
I was going to suggest what they did in their install. Can it draw air from the front side under the front storage area (drivers side)? By putting your intake near the floor you will be sucking out the coldest air in the trailer.
Eddie
Old 07-26-2018, 09:51 AM   #6
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Same problem here. If you find a good solution, i'm all ears (or eyes Ö for reading these posts)
Yes, you don't want to draw inside air to the "HOT" side.
I was going to crawl under our trailer to see if there is a vent in the floor.
Another problem, I think, is that the warm air vent grille on the outside, is too low and too small.
Old 07-27-2018, 11:28 AM   #7
Trailer: Parkliner
Iowa
AHA! I found the A/C air vents under the Parkliner. they are on a vertical surface in the fiberglass next to the frame rail. Lined with screening. 3 or 4 holes about 2.5 inch diameter. The "hot" air exhaust vent seems to be large enough. The fan inside the A/C should be enough to push that warm air out. But looks like a not very efficient fan. There just isn't enough room around there to supply sufficient air flow to cool the condenser coils.
Maxxair vent vs Fantastic vent? MinnesotaJill Modifications, Alterations and Updates 33 07-26-2014 08:54 PM
NEED replacement roof vent for 13ft Burro? davidbelitz Care and Feeding of Molded Fiberglass Trailers 3 10-10-2009 08:35 PM
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 05:41 PM
Need pics of vent on Trill 4500 Donna R Problem Solving | Owners Helping Owners 9 02-04-2008 02:24 PM
