Ice box drain - Fiberglass RV
Old 07-02-2015, 08:21 PM   #1
Ice box drain
First time ever trying out our '74 Boler ice box fridge. I thought it was pretty straight forward---the ice melt water flows down into the little black tube BUT the tube does not lead outside the Boler(?!)
It just stops, behind the fridge and drains there ..which is, of course terrible as I found a pool of water on the floor today. Weird thing is, I can't figure out where the tube 'should' connect to the outside world! I'm camping alone so I can't be inside and outside at the same time.
Along that outside wall I see just two holes: the hole for hose hook-up directly to our sink and the sink drain hole but nothing else. Where does the little ice box tube normally drain to? Mine is fairly short, but maybe it was cut? I can fit my hand behind the fridge to feel around but I can't feel anything obvious..
Thank you so much for any info. Hot week coming up in Ottawa, Canada!
TBirdy is offline   Reply With Quote
Old 07-02-2015, 08:46 PM   #2
Don't know where your drain tube is supposed to go to, but I did read the instructions that came with my Coleman cooler. It says not to leave the drain plug open. Says to leave that cold water in the cooler, because it is keeping stuff cold.
At some point you do have to drain it, of course.
Old 07-02-2015, 09:08 PM   #3
IllAnnoy
Replace the drain tube with a comparable sized Tygon tubing.
run it through the floor to a point just below the frame.
make the hole tight and you won't need to seal it.
Leave enough slack to allow sliding the tray out a little ways to clean it.
Your Icebox was designed to drain to the outside as the ice melts.
Some folks like to just put a bag of ice with a few holes poked in it, in the tray. If you can find it, block ice is better.
Or freeze a couple of milk cartons and cut the carton off before putting them in the tray.
The deep freeze at home makes a much colder block of ice than the store bought bags and can last more than twice as long.
Old 07-02-2015, 09:41 PM   #4
See the last item here. Then Google Coleman Extreme Cooler instructions. The instructions will cover any cooler since the principle is the same.
COLEMAN® XTREME™ COOLERS
How to use and clean
Xtreme Cooler Performance Guidlines
To achieve five-day performance in your new Xtreme cooler you must use it properly. Use plenty of ice and pre-chill items before you put them in the cooler. The following guidelines will allow you to achieve extreme performance.
37.5 lbs. for the 50 qt wheeled ice chest (model 6263-707)
43.5 lbs. for the 58 qt ice chest (model 6273-707)
27 lbs. for the 36 qt wheeled ice chest (model 6251-707)
Coleman recommends using .75 lbs. of ice per rated quart of the coolant. We highly recommend using cubed ice.
For best performance, always pre-chill food and drinks.
Two six packs or one gallon (3.7L) of liquid will use approximately 2.5 lbs. (1.13kg) of ice just to cool from room temperature. So plan ahead and cool off everything before you head out. You can even empty a few trays of ice into the cooler to pre-chill its interior.
Put the ice in last
Cold air travels down, so if you want your beverage well chilled, load cans and bottles first, then cover with ice.
Do not store cooler in hot location.
When storing cooler, avoid hot places such as the garage or the trunk of a car. If this is unavoidable, bring the cooler inside at least 24 hours before use.
Keep cooler out of the sun.
Ice lasts up to twice as long when the cooler is in the shade.
Choose cube or block ice.
Use cube ice to quickly cool food and drink, block ice to keep it cold longer.
Don't drain cold water.
Recently melted ice keeps food and drinks cold. Melted ice water preserves ice better than empty air space.
Old 07-02-2015, 09:57 PM   #5
Trailer: Compact Jr and Teardrop Trailer
An ice box is different than a cooler. If you do not drain it then you will have a mess.
rainjer is offline   Reply With Quote
Old 07-02-2015, 09:58 PM   #6
IllAnnoy
thank you.
Old 07-02-2015, 11:07 PM   #7
Just providing information on efficient use of a cooler. So, might be best to replace icebox with a cooler, or perhaps instead of replacing the drain hose, place the ice in some sort of container within the icebox so that you don't have to discard the cold that you paid for.
Old 07-03-2015, 06:27 AM   #8
Thanks all, but I'm still wondering where this tube was originally designed to drain to outside? Is there a hole in the Boler that I'm not finding? Seems crazy that the tube would exit the ice box through a little hole but then not leave the Boler entirely. Anyone have an original Boler ice box still in use?
Old 07-03-2015, 07:35 AM   #9
I have to agree with Glenn that a good portable ice chest makes a far better cooler than an icebox. Ice lasts 3-5 days in our Coleman 70-qt. 5-day Xtreme, versus 1-2 days in our Scamp's icebox (which we now use for dry storage of bread, cereal, chips, etc.). We also had issues with ants invading the icebox through... guess where... the drain tube!
If you are set on using the icebox, I'd pull it from the cabinet and add some additional insulation to the box. While it's out you can look for an existing drain tube hole or make one if needed. It's possible a PO replaced a section of the floor and didn't plan to use the icebox.
As Floyd suggests, now is the time to replace the tube, as old ones can get brittle and crack. Some screening on the end of the drain tube would reduce the likelihood of insect infiltration (but you'd have to check it regularly to keep it from plugging up). Mine extends past floor and frame so you can see it by looking under the trailer from the side.
I'd also look into putting plastic flaps across the door opening, like the big commercial walk-ins. Because cold air falls, opening the door of an icebox allows a lot more cold air to escape than opening the top of an ice chest.
If all this is more of a project than you want to tackle during prime camping season, I'd take Glenn's suggestion and let the ice melt in a tub for now and tackle this during the off-season. Just make sure you thoroughly dry out the floor inside the galley under the icebox.
Those are just my thoughts and experiences. Best wishes sorting out what will work for you.
Old 07-03-2015, 08:15 AM   #10
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
Mine isn't a Boler, but you might look in the same general location- the tube from the icebox in my Campster goes close to straight down, slightly angled back.
Containers are nice for cleanliness but if the water melts more slowly it also removes less heat. I use a 5-day cooler to store extra ice blocks (as they are nearly impossible to find while traveling)
Bobbie Mayer is online now   Reply With Quote
Old 07-03-2015, 08:36 AM   #11
Blocks last longer, but provide less cooling. Many Costco stores sell 20# bags of cubes for $1.79. It's a good deal, about the right amount for our 70 qt. cooler, and lasts about 4 days. Freezing all our meat ahead of time helps a lot.
I prefer to use containers for food that we don't want floating in melted ice water rather than containers for the ice. YMMV...
Glenn, you will point out that I should have 70 x 0.75 = over 50 pounds of ice (according to the instructions from Coleman in your earlier post, if I read that right...). Absurd! Sounds like lawyer-speak intended to protect Coleman from food-borne illness claims.
Old 07-03-2015, 08:46 AM   #12
KatieA's Avatar
Trailer: 1972 13' Boler
Yukon
We use the icebox in our '72 boler. The drain tube goes from the hole in the top shelf, down through a hole in the bottom shelf, and out through the bottom of the trailer. I'll add some pictures in a minute...
KatieA is offline   Reply With Quote
Old 07-03-2015, 08:51 AM   #13
KatieA's Avatar
Yukon
Here are the pictures...Let me know if you have any questions. We've never had a problem with water draining anywhere in the trailer so it sounds like you're missing the tube to the outside.
(Ignore the dirty icebox - my husband just finished replacing the floor and frame and I haven't cleaned anything up yet).
Icebox drain tube under trailer_from side.jpg   Icebox drain tube under trailer.jpg
Old 07-14-2015, 08:24 AM   #14
Amazing! Thanks so much all! Sure enough it was right where explained just a little hidden with some added spray foam insulation. Working great now. What a great forum!
Now... on to figuring out how to DIY an awning that will slip into the existing awning track. I know there's gotta be a thread on that!
Ice ice baby - an alternative to traditional a/c or hocus pocus? glamourpets Modifications, Alterations and Updates 24 02-02-2013 08:38 AM
Burro Ice Box Free jimtesla Classified Archives 6 10-25-2006 01:49 PM
Wanted: Ice Box for Boler Trailer Kurt in BC Classified Archives 1 10-15-2006 09:39 PM
Boler ice box wanted mrsfisher Classified Archives 0 02-17-2006 03:44 PM
Ice Box - Where to find? Sandy Gilpin Care and Feeding of Molded Fiberglass Trailers 10 12-09-2005 09:26 PM
