Ideas for breaker box cover? - Fiberglass RV
Old 01-29-2013, 07:38 PM   #1
Trailer: 2007 13ft scamp
We have a new/used 2007 13ft Scamp and have been cleaning her up for a few weeks now. The breaker box under the driver side dinette seat is missing the cover. I've called Scamp no help in locating one and put an ad on this forums parts wanted spot, 72 views but I guess nobody has one. We have a little furbaby (Maggie) that can't keep her nose out of anything. So, I'm wondering if anyone knows how to locate a cover or any ideas on how to make one? Any help would be appreciated. Thanks! I have a picture of the box but I don't know how to put it on here?
scamprookie is offline   Reply With Quote
Old 01-29-2013, 08:15 PM   #2
Breaker box picture
OH! Maybe this will let me put a picture of the breaker box?[ATTACH]54768[/ATTAC
Old 01-29-2013, 08:15 PM   #3
Yeah it worked!
Old 01-29-2013, 08:39 PM   #4
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Scamprookie, would something like I put in our Scamp work? Just added small wooden doors from a neighbor's kitchen cabinet renovation.
Old 01-29-2013, 08:52 PM   #5
I'm still not sure how to use this forum stuff. I quick replied to you but seems it doesn't show up. Any way thanks for the suggestion, I'll check in the am, I think it's pretty small maybe 12"x8". Maybe that would work. I also think the breaker switches stick out a little. Thanks for the help!
Old 01-29-2013, 08:59 PM   #6
Trailer: 1988 columbus coach van companion liberty
convertor cover
you might try to google wfco or centurion convertors they both have that appearance and have a plastic face cover that gets broken easily
if it is a centurion they are out of business but wfco is still current so should be able to replace it
m and m is offline   Reply With Quote
Old 01-29-2013, 09:22 PM   #7
WildBirder's Avatar
A quick neat looking fix is a spring loaded access panel. Lowes/Home Depot. It lays flat and thin on the exterior with a spring latch inside that allows you to slide the panel off.
Mark
1969 Boler
(#183)
WildBirder is offline   Reply With Quote
Old 01-29-2013, 09:36 PM   #8
Thanks! I'll look and see what type I have.
Old 01-29-2013, 09:38 PM   #9
Thanks alot! sounds like a good idea. Probably cheaper than original cover and if the original ones break easily probably would last better too!
Old 01-30-2013, 06:47 AM   #10
Raz
Raz's Avatar
Vermont
How about an old plastic container lid and some Velcro tape? Most hardware stores sell the tape. Raz
Old 01-30-2013, 07:12 AM   #11
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I like the Velcro idea. You could also use a piece of plastic paneling like they sell for bathrooms.
4 ft. x 8 ft. Gray .090 in. Fiberglass Reinforced Wall Panel-665041 at The Home Depot
Old 01-30-2013, 08:06 AM   #12
john
the ideas about just covering up the unit is not good
the only thing that holds the 110v breakers in place is the face you are missing,
loose breakers will cause heat and could cause a fire also the original face vents the heat and cooling fan for the convertor if just covered the convertor will over heat and could damage the electronics. it needs to be replaced with the correct cover
look at bestconvertor.com under cs3000 main board shows a pic of your convertor
maybe they would have a cover? or by knowing the brand and model be able to find a cover at an rv dealer these are being replaced daily at shops because of main board failures
mike
Old 01-30-2013, 08:20 AM   #13
Trailer: Casita 17 ft DLX SD
The factory cover (Dead Front) for a load center or a panel board is designed to contain the electrical arc if a fault occurs in the breaker panel and of sufficient mechanical strength for the purpose . . The cover must be mounted securely to the breaker panel box to make sure it stays in place during a fault usually with screws . Metal or flame resistant plastic or resin board (Non combustible - flame retardent)) is normally used for the panel cover to contain the arc and stop objects or people from getting burned .If you have ever seen a large electrical arc fault occur it is not a pretty site
Old 01-30-2013, 08:42 AM   #14
FPE Breakers
john
mike
The only panel I know of that used the cover to hold in the breakers was
FPE Stablok . FPE went bankrupt because they lost their UL listing and could not be sold in the USA almost 20 years ago . The UL does not allow the panel cover to hold the breakers in position to maintain contact . I changed out about 20 FPE panels in a hospital due to that every time you took off a panel cover breakers fell out of the panel endangering patients lives . The other problem with FPE was that the breakers failed to trip under fault at the proper current level
Wanted: breaker box cover scamprookie Parts: Buy | Sell | Trade 0 01-25-2013 04:56 PM
Wanted: UHaul Battery Box Cover? (CT or VT) djtriceflt Parts: Buy | Sell | Trade 16 06-22-2012 08:48 PM
Power Converter & Breaker Box $60 kentj Classified Archives 2 04-28-2008 10:51 PM
Exterior Storage box ideas Cam A Problem Solving | Owners Helping Owners 17 05-15-2006 05:41 AM
Tundra 04-05-06 Cover and Tool Box Terrance Classified Archives 0 12-06-2005 11:21 PM
