Identifying the Exterior of a 16ft 1979 Scamp - Page 2 - Fiberglass RV
Old 01-12-2015, 02:27 AM   #15
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Depending on where your water lines run and where you plan on installing it it would be an easy mod. Cut a hole, a couple tee's.........BTW, a multi tool makes a fine cut, very little dust and is very easy to control and doesn't chip the gelcoat like a jig saw. Just lay your outline out on masking tape.
Old 01-12-2015, 09:16 AM   #16
Originally Posted by Dave Frazer View Post
Thanks Bob. I will measure and make sure before I order anything.
I am considering the installation of a bib on the exterior with an outdoor hand held shower similar to some of the newer RV's. Thought it would be nice to stand up and be able to rinse off with warm water.
Has anyone done a similar modification?
I installed outside shower boxes on all three of the 13' FGRV's I added hot water to in the past few years. On the Scamp it can be a little snug behind the sink plumbing, but can be done. Plan ahead when you add the new faucet.
Try to find a shower port with a quick disconnect on the hose. (Two of mine are marked D&W Sales, Elkhart, IN) The box is smaller, and always tucking the shower hose into the box will eventually lead to kinks in the hose.
Help identifying a hitch on my scamp scamp2003wi Problem Solving | Owners Helping Owners 16 07-22-2014 10:37 AM
Identifying Scamp Window Leaks kdhanso Care and Feeding of Molded Fiberglass Trailers 5 10-12-2013 01:18 PM
Help Identifying an RV Aaron L General Chat 10 11-29-2010 06:00 AM
Need Help Identifying this Fiberglass Travel Trailer Joe Balla General Chat 33 03-29-2010 09:18 AM
Need help in Identifying ? Don N Care and Feeding of Molded Fiberglass Trailers 3 12-15-2008 07:16 AM
