If this Scamps-a-rockin - Fiberglass RV
Old 09-23-2012, 03:35 PM   #1
Trailer: scamp
Hey serious though pretty embarrassing question. I just got a scamp and I love it, one problem, when my wife and I are "intimate" the lightweight nature of the trailer is such that the rocking is very noticeable to people camping nearby. Is there any hope of stopping this or is it just one of the issues of a lightweight camper?
thanks!
mokash is offline   Reply With Quote
Old 09-23-2012, 03:45 PM   #2
Pam Garlow's Avatar
Trailer: U-Haul 1985
Now that's a question I haven't heard on this forum. But the standard way to reduce 'bounce' is to put stabilizer jacks under the frame at each corner. Don't lift the wheels off the ground, just tighten the jacks so the suspension won't bounce. Maybe also some memory foam on the bed, which has a deadening effect on (ahem) movement.
Old 09-23-2012, 03:57 PM   #3
Also add a sign. "WHEN THE TRAILER'S A ROCKIN DON'T COME A KNOCKIN!"
Gene Masse is offline   Reply With Quote
Old 09-23-2012, 05:51 PM   #4
Ed Harris's Avatar
Practice?
Old 09-23-2012, 05:55 PM   #5
Hi Mo, welcome to FiberglassRV, we're glad you're here. You've started with a bang! Yeah, stablizers on each corner will stop that rockin'
Old 09-23-2012, 05:57 PM   #6
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Many (perhaps most) travel trailers rock considerably even just when walking around inside. Stabilizer jacks are definitely the answer. My stick trailer came with them on both sides near the rear bumper, and with the main front jack also down my trailer is quite still.
Old 09-23-2012, 07:14 PM   #7
Trailer: scamp
In retrospect i could have just asked " How do i stop the scamp from rocking" but I guess this is more fun...
Old 09-23-2012, 07:20 PM   #8
Tonia's Avatar
Trailer: Scamp 13' (1982)
Wisconsin
Bahahaha! I bet there's barely a person on here who hasn't wondered the same at some point. :-)
Tonia is offline   Reply With Quote
Old 09-23-2012, 08:39 PM   #9
Pam Garlow's Avatar
...and by the way, Mo, that memory foam makes a very comfortable place to SLEEP (if the mood strikes you, what can I say, I'm crazy that way).
Old 09-23-2012, 09:51 PM   #10
MFF
Trailer: Boler-1300 1979
Quebec
Hi !
I've heard that when it is cold, the memory foam becomes hard like a stone.
Now here it is 41 F...and we are planning a few camping weekend .
Have you noticed that?
MFF is offline   Reply With Quote
Old 09-24-2012, 05:33 AM   #11
Raz
Raz's Avatar
Without rear stabilizers you could have a most uplifting experience. And I promise your neighbors will notice. . Raz
Old 09-24-2012, 06:34 AM   #12
Roy in TO's Avatar
Try tantric
Old 09-24-2012, 07:58 AM   #13
LukeP's Avatar
One note about using your stabilizers.... if you happen to be camping on a concrete pad, or even larger rocks -- the stabilizers can cause quite the scraping noise against the ground when you're "walking" inside. Lets just say your rockin' will amplified. Use some scrap wood (1x6, etc) to act as a pad on the concrete/rock, then tighten everything up.
Also, yes, FIRM memory foam can be hard as a rock in the cold. We had to send a mattress back because it would take our body heat a good 15 mins to soften the mattress, then you didn't want to turn over so you didn't start that process over --- turns out the wrong model had been delivered! Good thing because for a couple weeks, it was like sleeping on the floor. Our current foam is firmer when cold, but great after about 60 seconds. SO, check the firm/soft factor for cold weather camping! Of course, this would also impact the original question
LukeP is offline   Reply With Quote
Old 09-24-2012, 08:11 AM   #14
LukeP's Avatar
Also Mo, did you create a new user ID to ask that question?! Well done, if you did
Old 09-24-2012, 08:39 AM   #15
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Personally, I'd recommend a 400 kg depleted uranium flywheel coupled with a multi-axis dynamically balanced gyroscope controlled with a hardened-enclosure multi-axis accelerometer. In conjunction with a computer-assisted shifting weight system, this simple trailer modification should prevent any exterior exhibitions of inner-trailer stability-disruptive activities. Note that after installation this trailer would be limited to operation within the continental United States under DOD Critical Technology Ruling 2010-299/72 (as revised).
fusedlight is offline   Reply With Quote
Old 09-24-2012, 09:43 AM   #16
Word of caution in regards to using wood to block up a trailer. When wood gets wet it is very slippery! I used wood for a long time until one day my trailer take a short trip down hill (about 4') when someone pushed off a little to hard while stepping out of the trailer and the stabilizers slipped off the wood. The trailer actually did a little spin sideways, away for the wheel chocks as well, so they didnt do much to stop it.
A good reason to have a box of Plastic Leveling Blocks on hand - they work really well under stablizers, not just wheels. I also now use a tongue wheel chock as well.
Old 09-24-2012, 09:51 AM   #17
fusedlight's Avatar
I just picked up a set of those blocks these weekend... works like a champ!
Old 09-24-2012, 12:09 PM   #18
Trailer: U-Haul 16 ft Vacationer
We use Wayne's RV Stabilizers for all 4 corners of our VT to keep it very steady. I also add an occasional scissor jack if the ground is uneven. My wife does not like a trailer that moves when she walks (or anything else), so I probably over-stabilize it. Thanks for asking "The Question that Shall Not be Asked!"
Old 09-24-2012, 01:36 PM   #19
Trailer: Bigfoot 2500 truck camper
What about when boondocking in a parking lot? Do people use stabilizer jacks then? I don't. So if you are overnighting at walmart its probably best to pretend you have kids sleeping nearby.
Rene is offline   Reply With Quote
Old 09-24-2012, 02:17 PM   #20
Trailer: scamp 13
actually,,,,on reflection,,,, you know those chunks of tire on the highways that resemble an alligator crossing the road? a hunk of one of those under each,,,well,,,uh,,,love support, would help over come a lot of problems.
Do not neglect to show hospitality to strangers, for by doing so, some have entertained angels unaware.
Any Scamps in NC??? Locklear in NC Hi, I am.... 8 10-24-2011 06:25 PM
are old scamps lower than new ones? jmacchi General Chat 8 04-06-2009 09:29 PM
New Scamps FOR RENT Donna D. General Chat 9 03-25-2007 08:21 PM
Seattle Scamps? Dan Simon Problem Solving | Owners Helping Owners 9 03-14-2006 09:56 PM
16 ft V.S 13 ft scamps Legacy Posts Problem Solving | Owners Helping Owners 2 05-29-2003 04:10 PM
