Ignorance was bliss-80 Boler - Fiberglass RV
Old 08-04-2015, 06:45 PM   #1
immrbill's Avatar
I am getting new tires for my Boler on Thursday, I will be pulling off the current wheels and tires and having new tires put on the wheels.
I was fine till I read the answers on this forum about jacking up the
trailers. Some said don't use the axle. Others said use the frame. The axle can bend etc......Can it be that difficult.
My 1980 Boler has a leaf spring axle so where do I put the floor jack,
I'm leaving on a camping trip August 12th for a few days and would like to have new tires. The Carlisle's on it are dated 09
immrbill is offline   Reply With Quote
Old 08-04-2015, 09:22 PM   #2
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
If you can put your floor jack directly under the spring where it bolts to the axle, you will be fine.
or, you can put the jack under the end of the leaf spring where it is solidly connected to the frame with the bushing mount (not the end with the shackles). This will probably be your best bet, as it will allow the tire to drop and be easier to remove the tire/rim.
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
Old 08-04-2015, 11:32 PM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
The not-under-the-axle-or-it-will-bend comments were relevant to a torsion axle (big tube surrounds a bunch of rubber segments inside) and not to a leaf-spring design. You're good with a jack under the axle by the springs.
Charlie Y
tractors1 is online now   Reply With Quote
Old 08-05-2015, 09:20 AM   #4
immrbill's Avatar
Thanks
boler
There's a hole in my Boler my Boler my Boler FRED SMAILES Modifications, Alterations and Updates 230 03-19-2018 04:03 PM
Tires - My Bad, my Ignorance, my naivite! Michael Pupeza Towing, Hitching, Axles and Running Gear 4 08-24-2009 12:02 PM
Battery ignorance Fabienne M. Problem Solving | Owners Helping Owners 6 07-14-2009 03:13 PM
