I'm in trouble. - Fiberglass RV
Old 03-18-2014, 12:41 PM   #1
Name: Russ & Vivian
I'm in trouble.
At least I hope not. I have a 91 Scamp 16ft, I ordered replacement brake lights(Led) the old lights have red black green and white, the new ones have red black and green Please don't tell me I need the white one because its to short to use again
Shadow56 is offline   Reply With Quote
Old 03-18-2014, 01:07 PM   #2
The white wire shoul d be the ground and on a fiberglass trailer it is very necessary.
Here is a link to the color codes: Trailer Wiring Diagrams | etrailer.com
If you look under the dinette seats and pull up or cut the rat fur where you feel the lump from the wires, you can splice in a longer wire.
Old 03-18-2014, 01:25 PM   #3
Trailer: 2014 Escape 21
Virginia
Russ
Scamp uses the Bargman wiring color code. It should be in your owners manual or can be found here.
Fiberglass RV - Document Center - WiringDiagram_Scamp
If you ordered your lights from Chuck he usually gives the color code for his LED lights on the invoice or just send him an E-mail.
Eddie
Old 03-18-2014, 05:00 PM   #4
Mike Magee's Avatar
Trailer: Li'l Hauley
Just splicing on another piece of wire probably will do it.
How to prepare Tofu
Step 2: grill some meat
Old 03-18-2014, 05:25 PM   #5
Name: Russ & Vivian
Ok, I figured out the green wire is the running lights, so since the new lights didn't have a green wire I now have break and turn signals, no tail/running lights...lol
I don't run at night so shouldn't be a problem till I can order new lights.
Now the next problem is the rear water fill tube cover, you cant move the holding tank without undoing all the fittings, and its glued in from the outside, I have most of it chipped out but there's still about 1/4 in in there I have to work on tomorrow. Then it's off to Fastenall for washers and caps, Scamp didn't send enough, or I didn't order enough.
Trillium Elec. Trouble Chris McVeigh Problem Solving | Owners Helping Owners 10 04-26-2009 08:53 PM
AGI Financial trouble Ken C Money Matters 3 04-25-2009 07:21 PM
Awning trouble BobB Problem Solving | Owners Helping Owners 3 02-18-2009 04:55 AM
Big trouble with my door Dominique Problem Solving | Owners Helping Owners 3 08-23-2008 03:12 PM
Trouble with casita club validation James Disher General Chat 7 08-12-2008 12:20 PM
