11-19-2009, 05:46 PM
#21
What's your favorite way to heat an egg, and why?
I prefer to use a small electric "ceramic" heater if we have shore power. If not we have a "furnace" as part of the Duette Range Combo. The blower motor tends to run constantly though. While I have run the furnace through the night, I find a Down Comforter encased in a Silk Duvet keeps us warm while under it. (This works better if 2 of you are under there.) 600 thread count sheets help, too. Wearing socks in bed to keep your feet warm really help the rest of you feel warm. That way we turn off the furnace/heater while sleeping, and turn it on when we wake up.
11-19-2009, 08:29 PM
#22
Trailer: 13 ft Scamp 1983
We have the Wave 3, and use it in our 13', I have found it to be adequate, but would think that any larger of a space, and it would not be very effective. There is a larger unit called the Wave 6 that might take care of your needs, and it isn't much more expensive than the other ones. You can google it, to find a good price,this was the lowest I could find with out spending much time digging.
http://www.amazon.com/57341-Olympian-Wave-...r/dp/B000BV01CK
Best of luck to ya, keep us updated!
11-20-2009, 12:12 AM
#23
Trailer: 13 ft Compact II
When we used to have a Scamp 16, we used a Coleman Black Cat, which worked nicely at Toulemne Meadows high up in the Sierras at Yosemite. We used it to take the chill off, and never ran it overnight while sleeping for safety reasons. Sleeping bags kept us warm. It got down to 25 degrees outside, but we were cozy inside.
Now we have a Compact II with a smaller Coleman Sport Cat. Don't plan to do snow/winter camping though.
Donna is right on about window insulation; I'm going to try her 'foam behind the gravel guard' idea. Plus as I rebuild the C II, a lot of insulation is being installed.
For cold weather use, a carpet runner fastened down with double-sided tape might provide simple, temporary floor insulation.
Fran
74 Compact II
11-20-2009, 03:36 AM
#24
Trailer: Scamp 16 ft
The biggest heat loss and points of condensation in a lot of these trailers is from the single-pane windows. Since the Scamp has a plexiglass front window without a metal frame, the moisture from the inside of the window can be problematic. One solution is to use backpacker foam, cut to the gravel guard shape and either glued or just placed behind the guard and "locked" into place at night. The rest of the windows can be covered with insulation (Reflex?). Be sure to keep the vent open and air moving. Otherwise the trailer turns into a cold sauna.
If you plan to do much cold weather camping, you can insulate the floor by gluing blue styrofoam sheeting to the underside of the floor. Blue styrofoam is lightweight and doesn't hold moisture.
Donna: I am interested in learning a bit more about both of these insulation options, as I am unfamiliar with some of the products folks use on their eggs.
Can you give me a bit more description (or a link) to the backpacker foam you mentioned? That looks like a great idea!
For the windows, I see something at Home Depot called Reflectix --it's sold in a 4' x 25' roll. Is that the stuff? Any idea how to apply it to the windows? I would think it should be easily removed and reapplied, so it could be used just at night, for example. Or would you leave it on all the time in the colder months?
What about the blue styrofoam? Any specs or sources for that? Also, are there threads that discuss how to apply it to the underside of the floor?
Thanks,
Tom
11-20-2009, 05:16 AM
#25
Trailer: 2000 16 ft Casita Spirit Deluxe
I did buy an inexpensive Pelonis ceramic heater, for use when shore power was available. But I depend more on my very good down sleeping bag if it gets very cold. And, since most of the heat loss in our bodies is lost through the head, wear a warm knit hat to bed. The first item of clothing a knowledgeable backpacker sheds to regulate his temperature when beginning to overheat is the hat, and the first clothing item he (or she) dons at the onset of cold, is that very same hat. The same principle works at night, too. If it is really cold, the hat upon the head, while the head is stuffed deep inside the warmth of a good, down mummy bag. With the Casita now, If it becomes that cold, I'll likely head either lower or further south as soon as the morning sun is up above the horizon.
11-20-2009, 06:39 AM
#26
Thanks,
Tom
Tom, I bought a roll of backpacker foam at Target.. in the sporting goods section. It's available just about anywhere backpackers buy equipment. I used a couple of pieces of newspaper taped together to create a template of the window and cut the foam with a pair of really good scissors. When the foam isn't in use it hides under the front bunk cushion (stays flat that way too).
Yes, that's the Reflectix I was speaking about. You can get smaller rolls than 25'... or do as I did and buy car windshield screens for a buck at the Dollar Store. Make a pattern just like for the backpacker foam and cut to shape for each window. It's been suggested to use magnetic tape to anchor to the window frames. A piece on the frame and a piece on the reflectix. I bought a roll of magnetic tape that's 1/2" wide at a fabric store. It's sticky back. That will work on the reflectix, but needs something stronger to glue it to the window frame as that frame gets hot in the sun and I don't think the glue will hold for long. I'm going to use Windshield Gasket Caulk... it's designed for heat. Can get it at any auto parts store. I haven't done this yet. But know it's going to work as planned.
The blue styrofoam is available at big box stores like Lowe's or Home Depot. Check with them about the proper glue... you don't want it to melt. You'll need to put it in like a puzzle around the plumbing, etc. So they can also tell you how to cut it... some recommend a hot knife, but I've had good luck with a D-shaped saw and a thin blade. And the floor will need to be really really clean... as it probably has road rash, etc. and the glue needs to stick... don't want to leave styrofoam on the highway!
Good luck, I'm sure others will chime in with other info too!
On edit: I just read a post on a different forum where someone made a skirt of oiled canvas that they placed around the entire bottom of the their trailer (think 5th wheel nose curtain). That would work too and someone else stacks bales of hay around the bottom of their trailer to keep the cold and wind from blowing under. Just some other ideas.
11-20-2009, 12:28 PM
#27
I would vote strongly for the skirt option over the foam-glued-to-underside option for a couple of reasons:
1) From research and experience on houses with crawl spaces in Northern Minnesota, it works better to skirt around the outside and keep that warm, wind-free space underneath working for you (vs. insulating right under the floor and letting the cold whistle through underneath).
2) Although the foam (if it's the proper type) won't absorb moisture, it very easily could trap moisture between itself and your floor, which could cause rot. Yes, if there were a perfect bond on 100% of the foam and floor, and that were never compromised, it wouldn't; but how likely is that on an existing trailer, and after more road use?
First though, I'd do the obvious stuff on the walls/roof, and try a throw rug. If that wasn't enough, then I'd make some kind of skirting (but, the hassle factor is huge and may not justify it).
Another note from living in frigid, windy Northern Minnesota: Although cold just seeping through underinsulated walls is definitely an issue, a teeny-tiny draft will make you ten times colder. So stalk until you find any and all drafts and eliminate them.
Raya
11-20-2009, 01:45 PM
#28
John Mc,
You said dry camping with children in the winter. I wouldn't use any of the portable propane heaters with children around in a small trailer.
With children and most likely wanting to keep the trailer quite warm I'd suggest purchasing a generator so you can run an electric heater as much as you want. You'd still have to be careful with children and a heater that is loose on the floor or elsewhere. Most of the little cube heaters are cool to touch and do have tip over shut offs.
I'd also install a furnace. Now I have the furnace and what you need to know is that it takes lots of juice for the fan and will run the battery down. So using it can be limiting, such as not all night if you want the trailer quite warm. I've run mine all night but it only kicks on occasionally as I just wanted the chill taken off not a warm trailer.
Anymore, I snuggle under layers of down without the furnace on and just prior to getting up in the morning I reach over and turn the furnace on. BUT, that's just me...I have no children with me and know that if I did things would be much different.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
11-20-2009, 10:45 PM
#29
Trailer: 1985 Scamp 16 ft
I thought this would be a hot topic for these chilly nights. Thanks for all your thoughtful & relevant replies, as well as for any others I might have missed. ;>
We've wound up here with a broad collection of heating and insulating strategies. Let's develop it as far as we can-- it might become a useful "sticky" for future reference.
As for me, I've already lined the back of my cabinets with Reflectix. I like the idea of adding side seals to our night blackout curtains, that should help. Custom-cut foam panels would do much more to stop heat loss. A throw rug makes simple sense.
We'll always carry a cheap 1500 watt AC heater for CG's equipped with electricity. But we really do need a small furnace. Ironically, our Scamp still wears a double-vent-port grill from the Suburban Furnace that was removed by a previous owner. (Why, oh why did he do that?) FYI, Scamp's current Parts Dept. price of $365 for this unit is over $100 less than other RV suppliers I've found on the Net, so this seems like a golden opportunity. I know it's powerful enough, and it seems like the safest choice by a wide margin. I'll ask for it as a Christmas present.
Speaking of safety, and speaking especially to Roger, please don't worry about me. I knew that cooking with the windows shut was a risky practice. I just wanted to know how risky. I wanted to test how my new CO detector would react, to see if it was working properly. I was also testing the maximum possible heating capacity of the stovetop. Cooking certainly can heat up a trailer from warm to hot in the summertime, but I found that a ten-degree rise is much less noticeable when you're starting at 20 degrees rather than 80 degrees. In other words, cooking can make a trailer too hot, but it can't make it warm enough when you really need it.
12-28-2009, 08:47 PM
#30
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
I sit on mine
2007 Scamp 13' deluxe
