Installing 20 Amp American Converter charger - Fiberglass RV
Old 08-25-2009, 04:13 PM   #1
Trailer: 1992 13 ft Scamp
Looking for help with installing a American 20 Amp converter charger in my 13' scamp. Does anyone have a wiring diagram for install? Any help would be much appreciated.
Thanks,
DavidS
DavidS is offline   Reply With Quote
Old 08-25-2009, 05:55 PM   #2
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
Try this web page
http://bellsouthpwp.net/j/u/jutod/Inverter...ge/inverter.htm
Old 08-25-2009, 07:38 PM   #3
Wilder's Avatar
Trailer: 1993 Scamp 13 ft
Hi David, I can't help with the diagram (yet), but we just bought a 13' Scamp and I'd like to add one of those too. Where did you get the converter? Is it the same one that is optional from Scamp?
Wilder is offline   Reply With Quote
Old 08-25-2009, 07:58 PM   #4
Time to change your profile! You can do that through "My Controls."
Old 09-02-2009, 08:30 AM   #5
Wilder's Avatar
hey, thanks Donna!
Old 09-26-2009, 03:55 PM   #6
Trailer: Scamp 13 ft
we purchased a 20amp american converter for our 13' scamp from e-bay seller cat023 for 59.99 buy it now (got it less than 2 days later). the instructions are really useless however and i would like a diagram also, or at least some advice. scamp makes sure they don's give model #s since they charge $160, but i'm sure it's the same model (looks identical).
Margaret R-J is offline   Reply With Quote
Old 09-26-2009, 04:45 PM   #7
We have a couple of manuals in the Document Center for the American Enterprise converters. maybe you'll find something that will help...
<a href="http://www.fiberglassrv.com/manuals.html?pageid=593" target="_blank">Electrical
Wiring, Converters/Inverters, Batteries and Power Supplies</a>
Old 09-30-2009, 03:24 PM   #8
Subject: 20amp American Converter
Called Scamp, not a fruitful experience. Called American and got a very helpful tech. He recommends that you cut off the black wire that is pigtailed, at the pigtail. put in a 30 amp fuse on first available space at left (not the bar connector at top left). hook black wire to bottom of 30 amp fuse and it will protect the remaining fuses hooked to bar. As far as the battery input, the first to left fuse opening is for charger but the battery input positive can be hooked to ANY of the remaining openings. hook hot to one of the lugs below the fuses and place a 20 amp fuse in slot. the negative battery wire should be hooked to ground lug on back of converter. there is a (misleading) detailed photo if you click on the american site and then click on product models, or something like that. it is nice photography and shows the basics but is not at all thorough (which i mentioned to the tech.) I'm going to hook mine up and if it works you won't hear from me. If it doesn't, I will let you know.
Old 10-02-2009, 12:35 PM   #9
It looks like you have it...I use them regularly and have a couple in stock, contact me directly if I can be of any help, It is really not complicated.
Battery Charger/Converter John Jesse Problem Solving | Owners Helping Owners 12 05-24-2010 04:36 AM
Schematic to American 20 Amp Converter Charger? Robert Johans Problem Solving | Owners Helping Owners 6 03-26-2010 08:21 AM
Converter/Charger Sharon W Problem Solving | Owners Helping Owners 24 08-01-2009 06:39 PM
Converter/Battery Charger Pat M General Chat 4 05-06-2008 03:48 PM
Converter/charger Legacy Posts Care and Feeding of Molded Fiberglass Trailers 31 02-02-2003 08:47 PM
