Installing a 12 volt lighting system in 73 Trillium - Fiberglass RV
Old 08-14-2016, 03:49 PM   #1
Trailer: Bigfoot Spirit Wing
I just purchased a 1973 Trillium 1300 with no 12 volt lighting. I want to install a battery powered 12 volt system..Any suggestions? This trailer is all original and has a 110 volt plug in and it appears to have had 12 volt lighting at one time.
idlebabyboomer is offline   Reply With Quote
Old 08-15-2016, 11:08 AM   #2
ckayaker's Avatar
Trailer: Trillium 4500
Quebec
My '77 had no battery when I bought it. The PO always used 120 when camping. I got a battery, hooked it up through the old converter and voila, 12 volt lighting! Your experience might be similar. I have since removed the old converter and added solar power, but I suspect the original 12 volt wiring etc is still in your Trillium, so give my idea a try.
ckayaker is offline   Reply With Quote
Old 08-15-2016, 11:21 AM   #3
David Tilston's Avatar
There is a Trillium wiring diagram in the document center. That should help. You will need a converter / battery charger. Progressive Dynamics makes a good one, but finding a spot in a Trillium for it might prove challenging.
They also make a conversion kit for other converters. In this thread this conversion kit was used by itself. It fits in the space the original converter, that Trillium used. I like it:
Trillium 4500 replacement converter?
Old 08-17-2016, 03:37 PM   #4
Trailer: Trillium 1300
Hello - I installed this converter (WFCO WF-8735) in the space under the furnace. I also added an AC outlet and a DC accessory outlet at the same time.
Patrick M is offline   Reply With Quote
Old 08-17-2016, 04:25 PM   #5
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Originally Posted by idlebabyboomer View Post
...and it appears to have had 12 volt lighting at one time.
Does that mean the 12v fixtures have been removed? I wouldn't have thought the previous owner would have pulled all wires even if he removed the fixtures.
Random thoughts:
Where does a normal Trillium that size store its battery? Maybe the picture gallery at the front of the site has a picture showing it if none of the members volunteer the information. Under a bench, on the tongue somewhere?
'm guessing there are no taped up battery cables somewhere on or in the trailer. Inside the trailer and it's going to need a battery box that vents to the outside and not the inside. Even AGMs should be vented "overboard".
I'm also wondering where the battery charge wire is terminated at the trailer end of the tow connection cord. That might be another indicator of where the battery was.
Probably going to need at least a 4-6 fuse DC distribution block. One with a cover is a good idea. A converter is nice but in a pinch you could carry a charger for mid-trip replenishing the battery. Going to need a deep cycle battery that fits wherever you decide to put it.
Quando omni flunkus, moritati
Old 08-17-2016, 08:43 PM   #6
Thank you for the info. This Trillium has no wiring or converter so I am starting from scratch
Gerry
Old 08-17-2016, 08:45 PM   #7
Thanks Steve..I am going to get a converter and battery and start from scratch
Gerry
Old 08-17-2016, 09:51 PM   #8
Borden's Avatar
Name: Borden and Carole
New converter may have new features let us know how it goes.
1978 Ontario made Boler
Old 08-22-2016, 09:45 PM   #9
I have seen the battery mounted in the gaucho, a dinette seat, and on the tongue. I have reviewed all info in the document center. There is only one angle of the tongue, and it only has a propane tank.
Truth is, I am not sure that Trillium had a standard. On the trailers that I have had a good look at, There is a pair of larger gauge wires that run from the drivers side of the gaucho to the converter. This would make it convenient to put the battery on the tongue, or in the gaucho. The correct place would be on the tongue.
Old 08-22-2016, 11:31 PM   #10
I suggest you take to trailer to a electrician and have them inspect and install what ever you want. Just because 12volts won't shock you doesn't mean it's not dangerous is mishandled.
Byron Kinnaman is online now   Reply With Quote
light, lighting, trillium
Two 6 volt vs. 12 volt deep cycle kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Engel MR40F 12 Volt Refrigerator 12 Volt Freezer Mike-N-Laurie Misc: Buy | Sell | Trade 1 04-26-2016 08:05 AM
Mobicool propane, 12 volt, 120 volt cooler Nelmes Parts: Buy | Sell | Trade 0 06-10-2014 01:36 PM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
12 volt lighting problem david john Problem Solving | Owners Helping Owners 2 03-06-2007 03:08 AM
