Installing a Backup Camera on the TV License Plate - Fiberglass RV
Old 12-28-2009, 10:59 AM   #1
Trailer: U-Haul 16 ft Vacationer
My wife gave me a wireless backup camera and monitor for Christmas. The camera is fixed in place on a license plate frame, so I'll just have to replace the current frame and wire up the power. However, the license plate frame itself is angled in at the top and this would seem to be aiming the camera way above the hitch. We have a 2003 VW Eurovan and the license plate is on the lift-up back door.
Any suggestions for making this get the right view? If I put spacers in the top license plate holes to bring the plate out to vertical or beyond, I won't be able to open the back hatchdoor since the handle is right above the license plate. My fingers wouldn't fit in the space to operate the handle.
The camera is not adjustable on the frame, either. It is fixed at 90 degrees from the plate frame. I was thinking of cutting the bottom half of the camera/frame and just mounting that over the lower half of the current license plate frame, but that's going to look plenty odd, especially with the increased vertical orientation.
Old 12-28-2009, 11:02 AM   #2
Can't use one in Texas.
The camera (bottom of license frame) covers up the word Texas on my license plate.
That's illegal here in Texas.
P.S. Newer license plates have Texas on top. It would be OK for them.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 12-28-2009, 12:09 PM   #3
Gina D.'s Avatar
aren't those intended to go on the trailer, not the tug?
Old 12-28-2009, 12:21 PM   #4
I use mine to hook up the Casita. I made some brackets to raise the camera as can been seen in the attachment. My son tried to utilize one with his fifth wheel but the distance was too great to get good reception.
Alan #1119 is offline   Reply With Quote
Old 12-28-2009, 12:22 PM   #5
Old 12-28-2009, 12:55 PM   #6
Kevin,
Would it be possible to mount the camera on a magnet and then when you need it put the magnet on the license plate ?
Old 12-28-2009, 03:03 PM   #7
Thanks for the comments and suggestions thus far. Since the camera is attached to the license plate frame, I can't do the bracket route quite as easily. Also, I don't know if magnets might interfere with the wireless signal. Could be worth a try. I would need to have a quick hook-up/unhook connection for the the permanent wiring, though. Gina, this was marketed to put right above the trailer hitch on the TV so that you can see when the connection is lined up. Putting it on the trailer won't give the view I need or have the continuous power (no battery in the trailer!).
Just had a new thought... maybe the bracket idea would work. I would have to cut the lower part of the license plate frame off, leaving the camera and screw holes on the bottom piece. Then maybe I could attach a padded bracket (so as not to scratch the door paint) BELOW the license plate, attaching to the lower license plate holes that aren't current used for anything. This would clear the door handle and possible give me the lower angle for better viewing. This would put the camera just below the current license plate frame. It's a possibility!
Old 12-28-2009, 03:13 PM   #8
Judith Kennedy's Avatar
Trailer: 1984 U-Haul
If you mount on the trailer that dosn't have a battery, you could hook it up to the trailer light circuit. Just do as I do and always tow with the lights on. ( not a bad idea in any case )
What brand is strong enough to carry the signal from the back of the trailer ?
Judith Kennedy is offline   Reply With Quote
Old 12-28-2009, 08:07 PM   #9
CindyL's Avatar
Trailer: 16 ft U-Haul VT
Adding my two cents here - I purchased the camera, so that I can give up my job as directing the hookup. It makes me nervous, so I bought the two balls that match up when the trailer is lined up with a backkup camera system to help out. I tried to get a camera that was easy to install and could just connected to the license plate light. So much for that logic.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Smaller license plate shane n Modifications, Alterations and Updates 2 08-01-2009 07:48 PM
Putting a new license plate on a Scamp Monica M General Chat 6 05-27-2009 10:28 AM
Casita License plate costs Keith Williams Problem Solving | Owners Helping Owners 19 04-27-2009 06:30 PM
Backup Power? Art Davis General Chat 3 03-23-2007 08:04 PM
Gray Water Backup Legacy Posts Plumbing | Systems and Fixtures 1 08-04-2003 06:49 AM
