Installing an awning - Fiberglass RV
Old 04-09-2019, 11:56 AM   #1
Trailer: 13' Scamp
IL
Question Installing an awning
I bought a sailrite awning rail that I need to attach to my 13 ft. Scamp.
I bought the 3M VHB tape to bond it. I want to make sure I am doing this right. Can you please offer advice and help.
Thank you,
Tiffany
jonesy is offline   Reply With Quote
Old 04-09-2019, 12:27 PM   #2
John in Santa Cruz's Avatar
Trailer: Escape 21
CA
thoroughly clean the trailer surface, and use some isopropyl alcohol to remove any waxes from the surface. ditto wipe off the mating surface of your rail with isopropyl then let it all dry before applying the tape. Not sure, but I think I'd apply the tape to the trailer first, then peel the top and apply your rail to it With VHB you get ONE try, that stuff sticks really strongly, so make sure you get things straight before you let it touch down. I'd want a helper to hold the far end of the rail clear of the body while you start pressing down from your end, that rail looks flexible enough for this. do this on a warm or hot day.
I'd consider drilling and using a half dozen or so aluminum pop-rivets too, with sealing caps, to reinforce it, after applying it with the tape
good luck!
Old 04-09-2019, 02:24 PM   #3
A member here that owns a Scamp 13 was installing a bag awning a couple years ago and had to install the rail to the camper. I was in a discussion with her about how I had done it on our Uhaul. She had called Scamp and they recommended using a "peel type" pop rivet. They expand more to spread out the stress on the fiberglass. I don't think there is all that much difference actually but it was Scamps recommendation.
Old 04-09-2019, 03:10 PM   #4
If you have a problem with a pop rivet it will most likely pull out from the fiberglass side.
I suggest using screws and washers on the inside.
If you must use pop rivets then a washer on the inside is still a good idea.
Old 04-09-2019, 04:56 PM   #5
bsedwebt's Avatar
Trailer: Casita "Cozy-Casa"
Central Virginia
Use only 3M RM45 double sided adhesive VHB tape! Use only the 1.5" wide vinyl awning rail for enough mounting surface. Clean the fiberglass and micro sand it with about 1000 grit wet/dry sand paper in the area the adhesive strip is going. Sand the backside of the vinyl awning rail with the same sand paper. Clean both again with rubbing alcohol. Make sure you heat the awning rail in a pot of boiling water if needed to bend to fit to curves before sticking it on. Use 3M adhesion promoter sold in little square packets - use one packet for each mating surface. Apply the 3M RM45 tape along the entire length of the awning rail covering all the mounting surface area. When that has been installed and ready then treat the mounting area on the trailer with the adhesion promoter. Peel the backing off the awning rail tape and have a helper make sure you have it level (pencil marks work great) You only have one shot to get it right. IF done correctly it will last for years... Ask me how I know....
"Cozy-Casa" -- Visualize whirled peas
bsedwebt is offline   Reply With Quote
Old 04-09-2019, 05:03 PM   #6
bsedwebt's Avatar
Central Virginia
https://www.fiberglassrv.com/forums/members/44505-albums1791-picture12170.jpg
Old 04-09-2019, 05:05 PM   #7
bsedwebt's Avatar
Central Virginia
Old 04-09-2019, 05:06 PM   #8
bsedwebt's Avatar
Central Virginia
Old 04-09-2019, 05:07 PM   #9
bsedwebt's Avatar
Central Virginia
Old 04-09-2019, 05:08 PM   #10
bsedwebt's Avatar
Central Virginia
Old 04-10-2019, 09:11 AM   #11
Trailer: 2008 Casita 17 SD
I installed my aluminum Keder rail with 1/4" X 20 stainless steel machine screws on 1' centers, and large fender washers and Nylock nuts on the inside. All the mounting fasteners are inside the overhead cabinets so none of them show inside the trailer. Used Sika-Flex marine grade sealant in all the screw holes to maintain waterproofing. Might be a bit of "overkill," but it certainly ain't going anywhere.
Old 04-17-2019, 10:54 AM   #12
Trailer: Casita 17' Freedom Deluxe
South Carolina
Greg,
Where did you get your rail from? Can you use VHB tape instead of Screws? And did did you make the awning yourself?
TIA
John
johnwen1 is offline   Reply With Quote
Old 04-17-2019, 11:34 AM   #13
Originally Posted by johnwen1 View Post
Greg,
TIA
John
You can buy the aluminum Keder rail here: (Link below.)
https://www.amazon.com/dp/B01C04IUM8..._t1_B00T36O2NI
It's one 8 foot long section. FWIW, I only used about 6 1/2 feet of it where I mounted my rail.They also have the slide-in Keder tape as well, if you want to make your own awning, or you can buy one "pre-made." Whichever way you want to go.
I don't like the plastic Keder rails. I find that the aluminum ones are much stronger. And personally, I'm not a big fan of using VHB tape for holding something like this either, but that's just me.
Greg
Old 04-17-2019, 02:09 PM   #14
South Carolina
Thank you Greg,
I'll probably just start out with the vhb tape but will switch to the ss bolts/screws at the first sign of tape failure. I'm still a newbie and have not drilled any holes through the fg skin for fear of leaks/mistakes. I really do like your setup and am sure I'll give it a try BTW where did you put your spare tire? We had Larry G put on a spare tire hitch as we told Casita to leave the spare tire unmounted, no through bolt.
John
awning, scamp
Installing Awning Track Craig Broughton Problem Solving | Owners Helping Owners 17 08-15-2011 02:45 PM
installing an awning.... cpaharley2008 Care and Feeding of Molded Fiberglass Trailers 11 09-26-2010 08:31 PM
Installing an Awning Rail Paul Richter Problem Solving | Owners Helping Owners 16 09-26-2010 07:28 PM
Installing awning rail Ray and Amy Coapman Problem Solving | Owners Helping Owners 3 06-05-2009 09:53 AM
Installing an awning & add-a-room Legacy Posts Problem Solving | Owners Helping Owners 53 11-18-2002 03:28 PM
