Installing Brake Controller help - Fiberglass RV
Old 04-07-2006, 11:05 AM   #1
Trailer: 1985 Scamp
I need advice. I purchased a Brakeman Compact electrtonic trailer barke control from Kragen Auto Supply. Has any one ever installed a controller in a Eurovan? How do I get to the brake section of the van to do the wiring?
Thanks
llollio is offline   Reply With Quote
Old 04-07-2006, 01:16 PM   #2
Brian B-P's Avatar
I have not worked with a VW van, but there are generally only two choices:
  • the manufacturer provides a plug-in point under the dash (that's factory pre-wiring, which seems unlikely in this case)
  • the brake signal wire to the controller (normally red) is tapped into the brake light switch wiring
So, guessing that the desire is to get to the brake light switch wiring, that is usually done right at the switch, and the switch is normally mounted under the dash right on the brake pedal lever (or adjacent to it) so that pushing the pedal down triggers the switch. The biggest difficulty would normally be to figure out which wire is the right one...
Given what I have seen on an earlier VW, I would not be surprised if the Eurovan has some bizarre brake light switch location - odd configurations seems to be the VW way.
Installing a brake controller in 97 Plymouth G. Voyager kevin61 Towing, Hitching, Axles and Running Gear 6 04-28-2009 06:59 AM
Installing a brake controller on Chevy Astro Gary Little Problem Solving | Owners Helping Owners 3 09-23-2006 05:25 PM
Pod Brake Controller Gina D. Classified Archives 3 11-24-2005 05:34 PM
Brake Controller Legacy Posts Modifications, Alterations and Updates 0 02-13-2003 05:20 PM
Copyright ©2000 - 2018, vBulletin Solutions Inc.
