Installing new decals - Fiberglass RV
Old 06-06-2014, 09:36 AM   #1
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
If I get the energy up I'm going to clean my Campster, re-poli-glo it, and install the new decals (with decals I assume going on before Poli-glow.
SO here is my question- I have the poli cleaning solution, which I can use where the decals are (not sure I'll use it in the other spots where I just need new coats of poli.) If that doesn't take off the old decal remnants, what should I use?
Any hints on applying a large (18 x 6 inch) decal?
Old 06-06-2014, 09:52 AM   #2
Trailer: 17b Escape
Pick an edge with finger nail, heat area with hair drier and peal slowly.
remove residual glue with Goo-b-gone.
There will be a difference in sheen (shadowing) where the old graphics were
J Mac is offline   Reply With Quote
Old 06-06-2014, 10:04 AM   #3
Trailer: 17b Escape
You need, spray windex, masking tape, squeegee or credit card, paper towels.
To apply:
*place decal, with backing paper and transfer paper still on, where you want the decal.
*with masking tape, tape the top 1/2 inch edge of decal with one strip of tape to trailer. Smooth with squeegee or credit card. The decal is now "hinged" to trailer.
*lift bottom edge of entire decal until you are able to access the carrying paper but still maintain a taped edge. Peal carrying paper down, being sure decal does not make contact with trailer. Spray trailer with windex where decal will be applied while still holding decal hinged up. Allow decal to hinge down and smooth with credit card to remove bubbles. allow all to dry then remove transfer paper.
Old 06-06-2014, 10:21 AM   #4
Thanks for the detailed response.
So is the Windex still wet when the decal goes on? Or is that what the paper towels are for?
Old 06-06-2014, 10:28 AM   #5
Trailer: 17b Escape
Yes the windex is still wet when you apply the decal. Make sure the tape, that is used as a 'hinge' runs the entire top 1/2 inch border of decal. once bubbles are smoothed out lightly blot excess windex off with paper towel.
allow an hour for drying. then peal off transfer tape by slowly pulling as parallel to decal as is possible (so there is no outward tension).
Old 06-06-2014, 10:46 AM   #6
Thanks! Hopefully I'll get to it over the next week.
Old 08-05-2014, 05:27 PM   #7
Okay- front decal came off cleanly. Back decal, not so much. See photo. Not sure what the deal is. The dark is where the decal is gone. White is gone. Some of the beige is old decal, mostly gone, relatively smooth surface, but not perfect. The question is- should I do more? This took a combination of eraser wheel and Goof Off. I could try sanding (this isn't as far as I can tell fiberglass; it is the lower door panel.) I'm afraid of going too far and getting the paint.
Old 08-05-2014, 05:28 PM   #8
Here's the front:
Old 08-05-2014, 07:45 PM   #9
Trailer: 2014 Escape 21
Virginia
I have not seen a Trails West but most rear entrance trailer doors of this era are aluminum clad. You may have to clean up and repaint the panel or all the rear door panels to make it look right then apply your decal. I would try to find an epoxy appliance spray paint either almond or white.
Good Luck
Eddie
Old 08-05-2014, 07:58 PM   #10
I wondered if that would be the solution. White paint should be okay if I can't find almond. Then I can sand before painting. However, the issue isn't really the appearance as the old decal will fit right under the new- it's whether the new one will stick if the surface isn't 100% smooth.
Old 08-08-2014, 12:40 PM   #11
Can I apply the decal in the sun? I was actually about to start and went to mix up a soap spray bottle (no windex, so was using a few drops of dish soap in water) and our water went off. Local community water system and a survey put a stake through it about 1/2 mile up the line. Should be fixed soon but now it is about 72 and sunny.
Old 08-08-2014, 06:42 PM   #12
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
It was at least 90 and in the sun when I applied mine, and they were 9-10' long. No problems. Just work a section of it at a time.
New Scamp 5er decals Philmag1 Modifications, Alterations and Updates 8 01-21-2013 08:52 AM
New UHaul VT Decals Finished Kevin A Modifications, Alterations and Updates 11 08-30-2012 05:47 AM
New UHaul Decals On the Way! Kevin A Modifications, Alterations and Updates 14 06-22-2012 03:15 PM
Installing a new axle.... mcnick Problem Solving | Owners Helping Owners 1 02-05-2008 08:20 PM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
