Installing plexiglass windows/rubber seal - Fiberglass RV
Old 11-11-2015, 08:36 PM   #1
Trailer: Perris Pacer
Help! I have an '82 Perris Pacer. I'm putting new plexiglass windows on the ends. I am also putting up new carpet/hulliner on the interior walls. Any onsight on which is easier...putting the windows/rubber seal in first or put up the hulliner first. My thought is hulliner 1st but then will that make it harder to install the rubber gasket and plexiglass?
katycamp is offline   Reply With Quote
Old 11-11-2015, 10:55 PM   #2
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
I would put the liner in first, the finished product will look better.
If by chance you can't get the window in you can use the seal as a
ruler to mark out a clean line to cut to.
Fred
FRED SMAILES is offline   Reply With Quote
Old 11-12-2015, 05:00 PM   #3
Roger C H's Avatar
Cool Sealant
Whatever you do, DO NOT use silicone sealant.
Silicone does not adhere to fiberglass well but does coat the FG with silicone which prevents anything else from sticking.
Old 11-13-2015, 12:33 AM   #4
Roy in TO's Avatar
hull liner 1st. if you have the right gasket it will fit over the liner giving you a neat finish. Scamp sells the window gasket which fits over their "hull liner" many call "rat fur".
Old 11-13-2015, 11:26 PM   #5
Trailer: Perris pacer
Can I ask where u got the rubber seal ! I have an 89 Perris pacer ! Need to replace the rubber seals also ! About 11 ft per window !Thanks _! And Good luck !
mexbob5150 is offline   Reply With Quote
Old 11-14-2015, 09:04 PM   #6
Roy in TO's Avatar
http://www.scamptrailers.com/parts-s...ft-detail.html
Old 04-13-2018, 09:07 AM   #7
Trailer: Perris Pacer '87
VA
thank you
ValleyReb is offline   Reply With Quote
Old 04-13-2018, 09:08 AM   #8
amazing
you guys amaze me with your skills and workmanship
bob
windows
Plexiglass stationary windows in older Scamp SimplyLesa Problem Solving | Owners Helping Owners 8 07-14-2014 10:34 AM
U-Haul windows seal and rubber parts theman Problem Solving | Owners Helping Owners 5 02-19-2012 06:53 PM
Plexiglass windows anyone? Pamela H Problem Solving | Owners Helping Owners 8 08-09-2008 04:56 AM
Installing Boler Plexiglass Windows kevin61 Problem Solving | Owners Helping Owners 1 06-24-2008 08:19 PM
Tinting plexiglass windows Flygal Problem Solving | Owners Helping Owners 9 05-01-2008 12:26 PM
