installing propane line for Wave 3 heater - Page 2 - Fiberglass RV
Old 12-06-2008, 11:56 AM   #15
April Wilcox's Avatar
Trailer: 13 ft Scamp 1983
that's good... I just thought it wouldn't hurt to mention it, since they concerned me. I just ordered a 12' hose w/regulator on Amazon.
So can you use one regulator and put the T on that? Or should we use 2 different regulators for the 2 lines?
Thanks again for all the advice!!
April Wilcox is offline   Reply With Quote
Old 12-07-2008, 09:29 AM   #16
Joe Z's Avatar
New River AZ
April....
My "T" on the outside tank is before the regulator so i have a low pressure regulator on the tank side of the rubber hose and that regulator goes into the "T" on the outside tank "T". If you "T" in after the regulator on the trailer ( which is a different type of fitting) then you won't need another regulator as it is already on low pressure (which is what the heater needs).....
To make things really simple sometimes i just bring an extra 20lb tank from home and just put my regulator and rubber hose into that extra tank........ There are so many ways to do this and this is just one of many.
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 12-07-2008, 09:05 PM   #17
Joe, could you tell me more about the part that connects the hose to the heater? I will probably need one of those too.
Thanks for the pix!
Old 12-08-2008, 01:18 PM   #18
Joe Z's Avatar
New River AZ
Thanks for the pix!
April.....
That part that connects the rubber hose to the heater is nothing more than a homemade "L" .... Looking at the picture below you will see the 90 degree elbow which hooks to a piece of copper tubing that is sandwitched in between the two fittings. The hose I bought at Tractor supply and can be hooked to your heater without the "L" (the rubber hose end is the same fitting size that is at the end of my "L")....that part just happened to be on the heater when i purchased it used and i almost didn't use it as it wasn't needed.
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 12-08-2008, 01:22 PM   #19
Thanks again!
Old 12-08-2008, 03:14 PM   #20
Trailer: 2013 Escape 19
[quote]April.....
Joe
Attachment 17102
The "factory version" of that is available from Camco Manufacturing, which sells the Wave heaters. To quote their description: 90 degree elbow, 3/8" SAE mail with 3/8" SAE female connector. Full 360 degree swivel." Part number is 57633. I'm using one at each end of my copper line; one at the heater and one where I'm teeing into the existing system. At the heater end, it makes it possible to convert the side exiting connector to one that aims straight back, or up, or whatever you choose, in very little space. Cost is 11.95 plus shipping, so they're a bit pricey, but they have advantages in close quarters. Phone number to order is 800 334 2004. www.uscatalytic.com, but their website is not very good. You might search and find a better deal. They're not available at Lowes, but haven't checked elsewhere.
Parker
Parker Buckley is offline   Reply With Quote
Old 12-08-2008, 03:19 PM   #21
Parker
Just found this by entering "Olympian 57633" in Google. Not sure the link will work by the time it's posted. Either way, if you get to this site, you can see a picture of it.
http://www.folandsales.com/catalog.asp?pro...;showprevnext=1
Parker
Old 12-08-2008, 07:34 PM   #22
Thanks Parker! Saves us the trouble of finding it. Much appreciated!
Old 12-08-2008, 09:10 PM   #23
Joe Z's Avatar
New River AZ
Parker....
I also saved that link as it may come in handy
thanks,
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 12-15-2008, 08:26 AM   #24
Well, it turns out we DO have a leak in the original copper line that runs to the stove. I had a feeling something was not up to par. Gotta trust that gut feeling! We plan to run new lines sometime in the near future, luckily we have a coleman stove to use in the mean time.
We did successfully hook up and fire up our "new" wave 3, and it works like a charm!! Very toasty!
Old 12-20-2008, 01:28 PM   #25
Joseph and Melanie Castine's Avatar
Trailer: Casita 17 ft Spirit Deluxe sold it 2011
Hi there,
I am trying to put a T in a rubber propane hose. I thought I could find a brass barbed T with 1/4 inside diameter. NO luck!!!! Anybody have a source?
Thanks
Joe
Joseph and Melanie Castine is offline   Reply With Quote
Old 12-20-2008, 01:52 PM   #26
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
Hi there,
Thanks
Joe
I, too, have not found one. You may have to obtain either a 1/8" or 1/4" brass pipe tee and then use pipe threaded barb fittings like I had to do. Larry
Larry&Carrie is offline   Reply With Quote
Old 12-21-2008, 10:04 AM   #27
Thank you!!!! So I use a pipe T and then use a barbed/threaded fitting to connect hose?
OK. Now to find the T and three barbed on one end threaded on the other fittings.
Thanks
Joe
Old 12-22-2008, 07:36 PM   #28
Found the fittings today at Home Despot. Will try to hook it all up as soon as the temps get above 50 again.
Joe
propane
Wave 3 Heater Installation Parker Buckley Problem Solving | Owners Helping Owners 21 12-17-2014 08:54 AM
Wave 3 Cat Heater Not Available in Canada Michelle A Care and Feeding of Molded Fiberglass Trailers 10 12-14-2014 07:55 AM
Propane Line Don N Problem Solving | Owners Helping Owners 4 02-05-2009 08:23 PM
Have Olympian Wave Catalytic Heater User Guide rudock1 Forum Admin, News & Announcements 1 10-22-2008 04:37 PM
Wave 3 Heater install Gina D. Modifications, Alterations and Updates 14 06-04-2006 01:41 PM
