12-05-2008, 11:49 AM
Trailer: 13 ft Scamp 1983
We are going to have to add a line for our Wave 3 propane heater, in order to be able to use it. I wasn't sure if we needed to run a copper line like the one going to the stove, tap off the line that is already going to the stove, or if we can just use the black hose that I have seen used for other portable heaters. We do not plan to permanenetly mount the heater, so we can keep it portable. Anyone know the best way to go about this, I just want to be sure we do it the safest way. I think we are going to get a T valve for the tank. Niether one of us have much experience working with LP gas, so any help will be appreciated.
12-05-2008, 01:44 PM
Trailer: 1994 Casita Spirit Deluxe 16 ft
April....
We also have a Wave3 that we use portable and we set it up with a "T" at the tank outside and with the rubber 12' hose and a regulator(low pressure)......I just slip it under the door of the 16' casita we have with the aircraft type door and it works fine like that. If i wanted a more permanent setup i would just junction it off the copper line inside with a quick connect and a shutoff valve for safety..... but as of right now i am happy with the way it's setup.
Joe
12-05-2008, 02:07 PM
Thanks Joe, that sounds like a good solution, to keep it nice and portable. Do you find the 12' hose is long enough? I have seen some longer ones out there, but I don't know if a longer one is needed. I imagine we will keep the heater either right by the door, or on top of the stove. I imagine if we ever permanently mount it, we will run a copper line, but I thought it was good to ask here first, before we buy anything. I found this on Amazon, will this work for our heater?
http://www.amazon.com/gp/product/B000BQRCL8
12-05-2008, 04:36 PM
Trailer: 1983 13 ft Scamp
April---hmmmm I have portable heaters (Mr Heater) plumbed into both trailers, permanent in the Compact and semi-permanent in the Scamp. What I did in the Scamp was cut & "tee" the stove line and then hook a rubber line with a shut valve to the tee and hid the hose in the cupboard. Then when I hook up the heater, pull the hose out thru a hole in the bottom between the cupboard door and the icebox/pantry. The hose comes out enough to put the heater anywhere inside on the floor. In the Compact, since I removed the fridge, I used that copper line, put a shutoff on, then installed a 6' rubber hose. When not in use, the whole works is shoved into that lower cupboard. Only problem I have had is that Mr Heater seems to plug up-- upon research on their website, they recommend a filter when hooking directly to high pressure propane, which is what I have in the Scamp. Larry
12-05-2008, 05:28 PM
I noticed our copper line that is already installed, has a few "flat" spots, the hose isn't kinked, or bent, but pressed flat in a few spots. Is this a hazard? We did not find any leaks in the line, but did in the regulator, so that will be replaced for sure. My first thought was replace the copper line, but Kirk seems to think it's ok.
12-05-2008, 05:56 PM
Hi April,
I'm not "up" on RV standards, but in boats LP-rated hose is the recommended method these days instead of the old, "hard" pipe.
Is there a standard for trailers that is like ABYC for boats? (They spell out how to do things safely --- or at least one way to do it.)
I wonder how the new eggs are being plumbed for LP?
Raya
12-05-2008, 07:31 PM
Trailer: Casita 16 ft Spirit Deluxe
Hi April,
Raya
Our 04 Scamp 13 uses low pressure hose from the regulator to a bulkhead fitting on the front of the body, then uses 3/8" copper for everything inside the trailer. I'm about to run a new 3/8" line from a tee on the exterior side of the bulkhead fitting, across the front lower edge of the trailer, and back underneath to come up inside the closet area to connect to our Wave 3. Hose would be easier, but I thought I was using the standard method with the copper! Unless there is a compelling reason to switch to hose, I think I'll continue with the copper, especially since this is a permanent installation. I'll post a couple of pics as I go along if anyone is interested.
Parker
12-06-2008, 07:10 AM
April....
That link you sent for the regulator will work just fine and the 12' hose works for us as we just keep it in the front of the trailer facing the rear. (take a 12' length of rope and see if it works for you) I would like to someday do like the others and plumb in a permanent hookup but this works for now
Joe
12-06-2008, 07:44 AM
Thanks Joe, I think keeping it simple for now is key, some time soon we want to go out and use the trailer near Austin (Mule Shoe Bend State Park, $5 night the last I was there, is a little gem we found down the road from Pace Bend Park) while it's cold out, and fewer people are going out there to camp. They don't have any hookups, so we will be using battery/propane to power up and keep warm. It will be our first official camping test run without hookups. Of course we won't be going out there until we get our health back in order, darn those pesky holiday bugs, somebody passed along a nice little stomach virus to us over turkey day. But the worst is over and we are on the mend, ready to take life on again!
Here is another question: Should the T go on the tank first then the regulators for each junction? Or should it be the regulator first then the T?? The only other line we will be using right now will be for the stove, which we might not use, since we have a coleman stove.
I am still unsure about the flat spots in our copper line running to the stove. Should I be concerned about them? They don't appear to be so flat that the gas can not get through, just look like something that needed to be addressed.
12-06-2008, 07:47 AM
Trailer: Trillium 4500 and 17 ft Eggcamper
April, can you tell me where you got the Wave 3, and if I can be so bold as to ask, about what did it cost? The ones I've seen are $$$! Thanks, Vi
12-06-2008, 08:18 AM
sure... I found it on ebay slightly used but still looks new, it cost about $200 including shipping. New they are about $250 or more, so keep an eye on ebay, I have seen many used ones going through there.
12-06-2008, 10:46 AM
Trailer: Scamp 16 ft and Trillium 4500
April, can you tell me where you got the Wave 3, and if I can be so bold as to ask, about what did it cost? The ones I've seen are $$! Thanks, Vi
Amazon has them for $210 brand new:
http://www.amazon.com/Olympian-57331-Wave-...r/dp/B000BUV1RK
12-06-2008, 11:56 AM
good find Jake!
I wouldn't be concerned about the flat spots safety-wise but if they are too restrictive you might have trouble running heater and range at the same time.
| Thread Tools |
| Display Modes |
No events scheduled in the next 365 days.
