installing spring on Atwood jack - Fiberglass RV
Old 05-11-2014, 12:34 PM   #1
Trailer: 2009 Scamp 13'
Has anyone installed the spring on an Atwood 650kg/1000lb rear stabilizer jack before? I'll try to attach a picture, but in case I can't, the spring in question is the longer spring that allows the jack to snap into place under the bumper for storage. I've done this previously, but bent the spring in the process. Maybe someone has a method that works better? Most likely through misuse, I've broken these springs a few times over the years, and I might as well learn a better way to do it! Thanks.
Richard Davis is online now   Reply With Quote
Old 05-11-2014, 12:45 PM   #2
Easy Peasy, I just did a set of these about a month ago.
The one end of the spring is looped around the pin or bolt that holds the jack in place.
Hook the other end of the spring in place and, using a spring hook (Looks like a scratch awl with a loop bent into the end), pull down on the spring and slip the pin/bolt into place. If your jacks are currently welded into place you will have to drill out the pivot pin and replace it with a bolt. Not a big job either
Old 05-11-2014, 01:30 PM   #3
Thanks a million! That spring hook tool is the "secret ingredient" I was missing! I don't have one and didn't even know of their existence, but pictures on the web (once I know what to look for....) suggest they would be simple to improvise or to pick up at the local hardware. I really appreciate your reply! You made my day, and I'm not even a mother!
Old 05-11-2014, 02:00 PM   #4
The one I use sorta looks like this one:
https://www.google.com/search?q=spri...2F%3B599%3B373
Wait for it to load the second screen
Old 05-14-2014, 11:44 AM   #5
Bob, In spite of dozens of spring hook tools showing up on the Web, tracking one down at a local hardware store or autoparts store in Victoria has been surprisingly difficult! No wonder I'd never heard of the tool previously! Anyway, I found one yesterday and installed the spring easily. Thanks for your help. Now I hope I break a lot more springs so I can use that tool some more!
Installing Spring Spanke General Chat 28 04-16-2014 09:40 PM
Atwood Fifth Wheel Jack - Electric Motor instead of Hand cranking Gail Shook Care and Feeding of Molded Fiberglass Trailers 12 07-31-2013 06:26 AM
installing a atwood heater in a boler 13' andrew78 Modifications, Alterations and Updates 1 05-11-2012 02:42 AM
Electric Tongue Jack Opinions: Atwood vs. Ultra Fab Jane P. Care and Feeding of Molded Fiberglass Trailers 31 01-16-2010 02:41 AM
Spring Fever, Spring Cleaning BOBSMITH General Chat 0 02-20-2009 07:10 PM
