Insulated Box For Generator - Fiberglass RV
Old 03-04-2007, 12:08 PM   #1
Trailer: Ventura 12 ft
Hello Everyone; Has anyone made a insulated box to go over a genset to reduce noise?
Guy Pallister is offline   Reply With Quote
Old 03-04-2007, 12:29 PM   #2
Brian B-P's Avatar
Not me, but this has been discussed before. The problem is that building an enclosure which effectively insulates against noise without interfering with cooling, intake air supply, and exhaust, is not easy. By the time you're done, I would be very surprised if the result was as inexpensive, effective, or compact as just buying an enclosed generator (such as the very popular Honda EU2000i). If you're starting with an enclosed generator, then it would seem to me to be an even greater challenge to improve.
Old 03-04-2007, 05:59 PM   #3
Pete Dumbleton's Avatar
Even so, just having a roofless box around a generator will direct much of the noise skyward -- Worth a try with a few pieces of plywood leaning against the generator, presuming one already has a noisy generator.
Old 03-04-2007, 07:04 PM   #4
Trailer: Fiber Stream
Talking
If you have a hitch receiver on the back of your trailer, you could get a tag-along-generator enclosure.
Old 03-05-2007, 09:07 AM   #5
Guy,
"Nuestra Casita" has had the frame extended 24" in the front. She has a diamond-plate box with a kind of foil backed "felt" insulation. The insulation is usually used on the underside of a car hood, or on the inside of car doors. It was fastened to all inside surfaces with 3M spray adhesive. No back or bottom on the box. There is a door on the side, to correspond with the exhaust location and the top is hinged to allow more ventilation when outside temps soar. The intent was to protect the extra quiet 3000 watt Yamaha from curious fingers and prying eyes. Out of sight, out of mind philosophy. The box has served it's purpose and also reduces noise. I suspect the reduction of noise would not be very effective with an open-frame generator. There is sufficient clearance between the generator and box to allow access to operate the key switch and choke and to plug in the electrical cord. The box was custom built and fits on the TT frame rails. The top's hinge is 3 1/2" forward from the back edge and located in a trough which is open on the ends. This not only provides drainage, but stiffness and prevents contact with the Casita belly-band. The top tilts backward enough to not require any support when open. The box is sturdy enough to support my 180#s, with a piece of plywood to spread the weight. The plywood might not actually be necessary but why take a chance?
The only downside I've encountered... the box must be removed in order to change the oil or service the battery for the generator.
We've used it for 3 years like this without any problems.
Kurt & Ann K.
Old 03-05-2007, 12:48 PM   #6
Brian B-P's Avatar
It's an interesting idea, but everything about this entire product line makes me shudder. I can't imagine a better way to reduce the ability to control a trailer than to hook a mass on the back riding on a caster.
generator
Where to Put a Generator BAMA & Pachyderm Posse Problem Solving | Owners Helping Owners 4 11-06-2009 10:37 PM
Generator?? Monica M Fulltiming in a Molded Fiberglass Trailer 27 04-16-2009 09:22 AM
Generator vs Car Daniel V. General Chat 35 03-09-2009 11:17 PM
Generator John Adrienne Problem Solving | Owners Helping Owners 54 03-06-2008 05:34 PM
Generator Legacy Posts General Chat 2 05-27-2003 05:53 AM
