Insulating a Fridge - Fiberglass RV
Old 01-13-2010, 11:31 PM   #1
Flygal's Avatar
Trailer: 77 Scamp
might be a dumb question but now that I have the scamp torn apart I need to reinsulate around the fridge, can I just use plain old styrofoam board (white) or do I need more of those pink or blue insulated boards from home depot? not even sure what the diffenece is
Flygal is offline   Reply With Quote
Old 01-14-2010, 12:32 AM   #2
Perry J's Avatar
Some of the areas I camp in the summer are over 100 degrees and cool of to 85 or 90 at night.
I used the foil backed 3/4"white Styrofoam that you buy at Home Depot to insulate the refer in my Scamp 3 years ago. It helped quite a bit.
John
Old 01-14-2010, 10:43 AM   #3
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
I used the foil-backed "bubble wrap" type of insulation around my fridge. Theoretically, the foil helps repel "radiant" heat wave sources, while the insulator protects against the conduction of heat from the surrounding ambient air.
Old 01-14-2010, 01:58 PM   #4
Tom U's Avatar
Trailer: Fiber Stream 16 ft
Brandy - all the above solutions are good. To answer your question, Yes. You can use plain old styrofoam board. It may no be as efficient as the foil backed bubbles but it will still do a good job.
Tom - '79 Fiber Stream
There is no such thing as an all black cat.
Tom U is offline   Reply With Quote
Old 01-14-2010, 02:34 PM   #5
Rob L's Avatar
Trailer: Trillium 13 ft
The white bead board typically has an R value of around 3 per inch of thickness. The pink or blue higher density board is usually around 5 per inch. Not a huge difference but every little bit helps when you're trying to keep the eggs from hatching.
Rob L is offline   Reply With Quote
Old 01-14-2010, 05:59 PM   #6
Trailer: 1985 U-Haul CT13 / 1990 Chevy S10 PU
I used white bead board (1") attached with contact cement. Bottom line is thqt no matter what you use you will only get a couple of days on a milk jug of ice. We keep a Coleman cooler in the TV and transfer food back to the U-Haul icebox as needed.
Eric Nelson is offline   Reply With Quote
fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
4-way fridge Daniel V. Care and Feeding of Molded Fiberglass Trailers 7 03-15-2009 05:24 PM
3-Way fridge Garrett D. Problem Solving | Owners Helping Owners 3 01-26-2009 06:32 PM
Fridge Flygal Problem Solving | Owners Helping Owners 3 07-10-2008 05:41 PM
Fridge Legacy Posts Problem Solving | Owners Helping Owners 15 08-09-2003 12:28 PM
