Insulating Door??? - Fiberglass RV
Old 05-13-2013, 06:59 PM   #1
Insulating Door???
I have the Door to my 74 Boler off and the window out. Anyone try insulating the door? Any suggestions? Any help is appreciated.
I do not want to separate the door.
Nelmes is offline   Reply With Quote
Old 05-13-2013, 07:30 PM   #2
Well, that leaves adding something to the interior and doing something with the window.
Is the interior of the door fiberglass WITHOUT any upholstery, rat fur, ensolite, etc? If there is, I'd remove it and add extra reflectix under it. If there isn't, maybe you could make something out of reflectix and put it in a nice cover and either snap it to the door or velcro?
You can create an inside panel out of plexiglass and install that to the inside of the door window to create a faux dual-pane window.
Other have any ideas?
Old 05-13-2013, 09:32 PM   #3
Trailer: 73,75,78 13' Boler 78 17' Boler
Not sure about insulating the door. I haven't looked at that yet, but might be able to fill it with door and window foam (from a can).
Willys is offline   Reply With Quote
Old 05-13-2013, 10:02 PM   #4
Thanks for the ideas, Donna D and Willy's!!!
The door is striped bare for repairs. I have upgraded the window and feel it should be ok with the curtains. Would like to fill inside the door. Plan on cleaning out the door latch mount (it's mostly rotten), so there will be nothing inside to hang up on.
Like the idea of spray foam, and covering the inside of the door.
Any other ideas?
Old 05-14-2013, 05:18 AM   #5
Just be careful of spray foam. Some brands will "over swell" and may distort your door. We've had this same discussion about insulating double-hull trailers (Burro, U-Haul, etc.).
Old 05-14-2013, 06:10 AM   #6
uhaulin's Avatar
Trailer: Uhaul ct-13
When I was 17 I worked for a carpenter framing houses. I was sent to the hardware to get spray foam to put around the windows in the house before the drywall went in. Oops I bought a high expansion foam. Well the outcome was that the foam broke half the windows in the house. Needless to say it was a bad day for me.
uhaulin is offline   Reply With Quote
Old 05-14-2013, 06:14 AM   #7
Good to know, What is used to insulate those trailers?
Insulating my uhaul ct13 theman Problem Solving | Owners Helping Owners 11 07-06-2013 07:35 AM
Insulating??? aaronmt Modifications, Alterations and Updates 2 06-13-2012 03:28 PM
Insulating 1982 Perris Pacer (Scamp clone) Misfit_Mama Modifications, Alterations and Updates 8 02-29-2012 10:15 AM
Insulating a Burro Andy B Modifications, Alterations and Updates 16 01-02-2011 09:49 AM
Insulating a Fridge Flygal Problem Solving | Owners Helping Owners 5 01-14-2010 05:59 PM
