insulation lifespan limited? - Fiberglass RV
Old 08-24-2013, 09:28 PM   #1
Trailer: 73 Boler 13 ft
Every time I look at the ceiling insulation in our Boler17, that I painstakingly scrubbed and painted, there is another bubble where it is not stuck to the roof anymore! I don't remember all these problems last summer. One friend had suggested we strip it all out, and use a new product for insulation, but we like original, and that also seems like an enormous job! Hubby bought a 3M headliner spray adhesive, but the fine print says "Not for foam." Does the foam ceiling, ensolite just deteriorate, and split apart after 30 years? Is this what we can expect to continue...groan. Any ideas and helpful advice appreciated.
Peggy is offline   Reply With Quote
Old 08-24-2013, 09:34 PM   #2
Brian B-P's Avatar
There are two products which were used by Boler, and they were very different. When considering suggestions, be sure that you have the same stuff they do.
The usual Ensolite is black rubber closed-cell foam with a tough textured skin; it is sometimes called "elephant hide". The other material is a soft yellow open-celled poly foam with a thin "popcorn" textured skin.
Old 08-24-2013, 10:03 PM   #3
Oh, thanks Brian. I have the popcorn, as you can see in the photo, with the open cell, now more open, I guess, foam. You have a Boler 17, don't you? Is the same thing happening?
Old 08-24-2013, 10:20 PM   #4
Brian B-P's Avatar
Actually, I can't see the photo (or the other photos in your other posts)... I don't know if it's just me.
I do have areas coming unglued in my popcorn foam. Sorry... no fix. I pulled some away from the fiberglass to install a roof vent and a light; in those cases, I had access and sprayed a 3M adhesive to re-attach it.
Old 08-24-2013, 10:40 PM   #5
okay, thanks again. I can see the photos in the middle of my thread, but it's the first time I have done photos. If others can let me know if my pictures are invisible. Thanks!
Old 08-25-2013, 06:06 AM   #6
Rick Mooyman's Avatar
Trailer: 1971 Boler
I don't see any pics in this thread.
Rick Mooyman is offline   Reply With Quote
Old 08-25-2013, 06:23 AM   #7
, I too cannot see the pictures. Are you trying to link to your album?
New Member Looking for a Trailer for Limited Offroad Use portager Hi, I am.... 15 07-21-2012 05:18 PM
limited general chat yyyyyguy Forum Admin, News & Announcements 11 02-15-2012 01:15 PM
Bearing Grease Lifespan melissab Towing, Hitching, Axles and Running Gear 6 05-14-2011 12:36 PM
Camping in Quebec - my limited experience Andrew GPSMapNut Camping, Campout Reports 3 01-18-2011 11:45 PM
Torsion Axle Lifespan David Schroeder Towing, Hitching, Axles and Running Gear 14 01-25-2007 05:25 PM
