Interior lights don't turn on (boler 1700) - Fiberglass RV
Old 06-04-2017, 07:38 PM   #1
Hi everyone,
I just bought my first boler 1700 last week. During the inspection I checked all electrical, gas and plumbing. Everything worked great!
Now that I have it home I charged the portable 12v battery and tried turn on interior lights but nothin seemed to work. This there a switch or something I need to flip to draw power from the 12v battery or something?
Thanks,
Adam
AdamP85 is offline   Reply With Quote
Old 06-04-2017, 09:23 PM   #2
Pete in NJ's Avatar
Trailer: Scamp 13 standard w/front bunks
East Coast
Sounds like something may have shaken loose on the way home. Check the battery connections.
Pete
15 Nissan Frontier Crew Cab v6 (main TV)
Petesblog.com
Pete in NJ is offline   Reply With Quote
Old 06-05-2017, 05:27 AM   #3
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
If there is a fuse on the positive battery cable, check that also.
Old 06-05-2017, 02:11 PM   #4
Trailer: '79 Boler 1700
Manitoba
We have a 1700 Boler and the manual for the converter shows there is a fuse or a circuit breaker. It's possible the fuse doesn't work, is missing or the circuit breaker popped due to overload. Check the fuse or reset the breaker if that's the case. The unit should switch automatically from 110 to 12 volt, but ours doesn't always do that and we need to reset the breaker.
CA Douglas is offline   Reply With Quote
Old 06-05-2017, 09:23 PM   #5
Hi guys,
I got it fixed. It was the fuse.
Thanks for the help!
Cheers,
Adam
Old 06-06-2017, 12:14 AM   #6
Borrego Dave's Avatar
Originally Posted by AdamP85 View Post
Hi guys,
Cheers, Adam
Very good, but you might want to check your connections to make sure everything is tight. That may have been the reason for the blown fuse.
boler, light, lights
LED Tail Turn Signal Running Lights for 13' Boler HawkBoler72 Modifications, Alterations and Updates 10 05-27-2016 09:14 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Boler 1700 Side Marker Lights timmckee Modifications, Alterations and Updates 6 08-15-2011 01:57 PM
1980 Boler 1700 For Sale - Interior fully Renovated Roger R.W. Classified Archives 4 05-21-2010 09:49 PM
Using side marker lights as turn signals al gilliland Care and Feeding of Molded Fiberglass Trailers 30 08-14-2009 04:53 PM
