interior paint - Fiberglass RV
Old 06-03-2009, 09:37 AM   #1
What is the best way to paint the interior fibreglass? The inside was painted once before by the last owner. Gewne
Gene B is offline   Reply With Quote
Old 06-11-2009, 02:16 PM   #2
Naomi P's Avatar
Trailer: 1975 13 ft Boler
After much research on these boards we painted the fiberglass with melamine paint after a good cleaning and a slight rough up with some sand paper. We painted the ensolite with a kitchen/bathroom latex paint.
Hope this helps.
Naomi P is offline   Reply With Quote
Old 06-26-2009, 09:32 PM   #3
Trailer: 1976 Boler 13 ft
I cant believe i dont remember the name of it but i used some wickedly toxic flexible paint i got at lordco. it was reccomended to me at a rally. (i must not remember b/c of the fumes ) I only did it last year too, how quickly the brain cells go when in a confined space. I did use a respirator after i started, i had too. if you want i could look it up. I am really satisfied with how it turned out. It is made for vinyl i think. It comes with a vinyl prep wash that you need to use. you can see the finish in the background of the kitchen pic. Good luck
cyndi H is offline   Reply With Quote
Old 06-27-2009, 06:10 AM   #4
You're going to have an addition problem... what kind of paint did this last owner use... acrylic, oil-based, latex, etc? You won't have long lasting results if you try to top coat this paint with a paint that doesn't adhere. For instance, putting oil-based over latex.
If you're looking to remove the old paint first, you might want to look into this:
RemovALL paint remover. I understand it works well on fiberglass, but is sloooow reacting. So leave it on for a while (like overnight).
paint, painting
Paint for 1978 Scamp interior fiberglass? Nancy Hoffman Care and Feeding of Molded Fiberglass Trailers 3 06-23-2010 11:28 AM
Scamp interior paint Nancy Hoffman Care and Feeding of Molded Fiberglass Trailers 8 11-13-2009 06:51 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
outside paint job Legacy Posts Problem Solving | Owners Helping Owners 11 04-04-2003 07:44 AM
Paint Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 03-21-2003 01:14 PM
