Interior Window weatherstripping/trim - Fiberglass RV
Old 09-30-2013, 07:07 PM   #1
Trailer: Acorn
Wisconsin
I have an older Acorn/Scamp with the Ensolite covering. For the others out there with the same wall type covering, what do you have around your interior windows? The ensolite in mine just stops and there is nothing between where it ends and the window edge begins. I think it looks incomplete. Is there something I can add that will help and make it look finished?
Thanks
dogtracker is offline   Reply With Quote
Old 09-30-2013, 08:26 PM   #2
Trailer: '77 Scamp
My Scamp has a white vinyl trim around it. Probably the same trim as the trim that covers the sesams. It may be heated with a heatgun to conform to the curves. The seam tape that Scamp sells has adhesive that sucks. If you use that, plan to use another form of glue with it. I used rubber cement and it works fine but a little hard to deal with if you have a lot to do.
Otters is offline   Reply With Quote
Surfside interior seam trim ? serious sam Problem Solving | Owners Helping Owners 9 08-13-2013 04:21 PM
Source for Interior Trim Needed dale k Modifications, Alterations and Updates 3 06-15-2013 11:18 AM
escape hatch interior trim sugermc Problem Solving | Owners Helping Owners 0 06-08-2011 06:50 PM
Surf Side- interior wooden window trim Jason, M Problem Solving | Owners Helping Owners 5 08-03-2008 12:31 PM
window trim Isaac Problem Solving | Owners Helping Owners 8 08-31-2007 07:52 PM
