Intermittent hot water - Fiberglass RV
Old 08-19-2009, 06:56 PM   #1
Bruce & Melissa L's Avatar
Trailer: 2007 Bigfoot 21 ft
Hello there, our 21' BF trailer has a hot water system that works but the supply of hot is intermittent with colder water, alternating every few seconds. It seems that it may be triggered as the water pump kicks in. Do any of you RV vet's know what the cause of this issue may be?
much appreciated!
Bruce & Melissa L is offline   Reply With Quote
Old 08-19-2009, 08:53 PM   #2
Trailer: Boler 13 ft 1972
much appreciated!
Check where the water lines exit & enter the hot water heater. Make sure that the bypass levers are parallel to the lowest line (Cold water) entering the waterheater & the upper line that is exiting the water heater is the (Hot Water) line. Sometimes there is a bypass line between these two lines, THIS LEVER SHOULD BE ACROSS THE LINE NOT PARALLEL.
Cheryl Lee is offline   Reply With Quote
Old 08-19-2009, 10:03 PM   #3
Thanks, we will check that first.
Old 08-26-2009, 10:13 PM   #4
Cheryl - thanks, your advice was right on.
Hot water coming out of the cold water side Matthew A Problem Solving | Owners Helping Owners 0 06-01-2010 09:37 AM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
Intermittent heater Greg Janke Problem Solving | Owners Helping Owners 8 05-19-2007 12:07 PM
