Inverter wiring - Page 2 - Fiberglass RV
Old 07-25-2008, 02:58 PM   #15
WHO YOU CALLING A [b]WIRED NUT
Isn't there something about shoe and fitting?
Old 07-25-2008, 03:04 PM   #16
Joe MacDonald's Avatar
if the output on your inverter has only 2 wires, it is only 110 volt- any plug designed for 220 won't give full voltage.
half of your circuits will probably not work because of the 220 input normally required ( a jumper would have to be installed in the panel or at the rv plug). You also don't mention a ground wire. 120 volts with no ground connection can be a real hazard.
How many prongs on the factory plug...3 or 4?
if three i think it would be 120v 50 amps
if four i think 220v 50 amps.
Joe
Old 07-25-2008, 03:05 PM   #17
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
phew..... knew there was a reason I go barefoot when I can.
Coach George Jessup is offline   Reply With Quote
Old 07-26-2008, 12:28 AM   #18
Pete Dumbleton's Avatar
I believe the two terms 'wire nuts' and 'twist locks' are more or less interchangeable. They are just fine for use in something that isn't going to move much, like a park model. Some of us on here are 'weird nuts'.
I was at a BLM CG in Utah and they gave the camp host an interesting arrangement for comfort -- In addition to having constructed a big lean-to to park his rig in shade, they provided a trailer that had a large solar panel on it, a big bank of 12VDC batteries and a generator.
Old 07-26-2008, 12:35 AM   #19
After removing the back of the inverter and seeing only one +Pos and -Neg feeding the 4 outlets on the back of the unit the conclusion seems to be to just plug in two cords too two outlets... wire them togehter for 30amps and feed this to a female RV outlet. Then Im good to go.
Thanx for ya'lls bit in figuring this all out
Inverter question Rick kl General Chat 5 08-24-2009 01:38 PM
Inverter Recommendations? Lisa H. Problem Solving | Owners Helping Owners 7 03-08-2009 03:01 PM
Wiring requirements for 1200W inverter install VIDEO kevin61 Problem Solving | Owners Helping Owners 0 07-29-2008 06:44 PM
Wiring Inverter, Converter, and Power Transfer Relays. GeorgeR Modifications, Alterations and Updates 3 01-31-2008 10:50 AM
Inverter Problems Jeremy Witt Problem Solving | Owners Helping Owners 3 09-15-2006 09:44 AM
