inverters - too much battery drain? - Fiberglass RV
Old 07-17-2008, 09:12 PM   #1
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I have a 600W inverter hooked up to the battery in my trailer. I use it to run one of those under counter GE radio/CD player units. is the inverter drawing way more than it's worth. it wouldn't be on more than an hour a day... just to get the weather and hear a little music.
Scott S. is offline   Reply With Quote
Old 07-17-2008, 11:07 PM   #2
Charlie R's Avatar
I would suggest you go out and buy a D/C car stereo CD player and speakers. It will take up much less space and will not drain your battery nearly as fast as an inverter will. Adding a solar panel will help keep your battery bank charged up. Your inverter could be used for computer and small power tools etc. for short lengths of time, provided you have good batteries and a means to charge them. You never want to drain your batteries to less than 50% charge as they will never hold a good charge after that. I recommend using 6 volt golf cart batteries in a series to make 12 volts. They can be drained and recharged many many times without ruining them.
Charlie R is offline   Reply With Quote
Old 07-18-2008, 08:57 AM   #3
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
I suggest you get a 75-150 watt inverter which will probably have much less of an internal power need, but in general, unless you're a Power Dry Camper, I wouldn't worry about the 600 watt unit being a big load.
Patrick M. is offline   Reply With Quote
Old 07-18-2008, 09:10 AM   #4
Gina D.'s Avatar
West Coast USA
anytime you can replace a 120v item with a 12v item ... do so. And there are darned few items you CAN'T get in 12v.
Inversion will always have inefficiencies.
A hint for your computer (If it's a laptop)... run it off the battery.. NOT inverted. Run the battery to nothing if you wish... plug it into your car to charge, yes, with an inverter, while the comp is OFF. Charging this way uses diddly and only takes an hour or so to be up and running again.
I have a 100 watt inverter for just this purpose, and I haven't dented my car battery with it... ever.
But.. back to your radio.. get a car system as suggested, or you could even get a "survival" radio that has a dynamo recharge. Thats all I use for news etc. I even have unpowered computer speaks attached to it for small sessions of music if I choose.
Old 07-18-2008, 09:52 AM   #5
Scott S.'s Avatar
Manitoba
good advise. I guess i was after the compact look. some re-thinking to do now... including solar recharging which would solve all my woes.
thanx folks
battery
Clock battery drain? Wilder Problem Solving | Owners Helping Owners 5 10-19-2009 04:31 PM
Battery Drain Donna & Chris Problem Solving | Owners Helping Owners 8 08-02-2008 09:15 PM
Battery drain Francine P Problem Solving | Owners Helping Owners 8 05-06-2006 04:50 AM
Battery drain Dan Simon Problem Solving | Owners Helping Owners 9 02-11-2006 08:09 PM
Battery drain Legacy Posts Care and Feeding of Molded Fiberglass Trailers 25 04-04-2003 08:14 AM
