02-01-2014, 09:32 PM
#21
Trailer: Titan GN Horse Trailer
When I have to use bagged ice as a replacement, I ensure that I take a large storage container with tight lid (Tupperware or similar). This way, I can put large amounts of ice in a cooler (or in an icebox) without it leaking all over. In fact, if you bought the right size containers to fit the shelf/tray in an icebox, you could freeze water in them at home and then refill with whatever ice you were able to purchase later in the trip, if blocks were not available.
But I have used 1/2 gallon milk container jugs filled with water and frozen whenever possible for my ice-chests. I also bag as much of my icemaker ice as I can before trips because my cubes are 3 times the size of those purchased. I put a quilt over my ice chest and put it in the shade (this is for canned/bottled beverages) and then keep a separate ice chest for food. I am considering an ice box for the living space in my horse trailer and I'm glad to discover that they exist.
02-03-2014, 07:49 PM
#22
Name: Steve and Janna
Trailer: '02 Scamp 13
We may be a little atypical, but we pulled the 3 way Dometic fridge out of our Scamp 13, along with the stove. I sold the fridge and bought an over sized Coleman ice chest. We do our cooking out of doors and that's where we keep the ice chest - or in the van if bears are lurking around. (I modified the stove for outdoor use.)
The cooler holds a lot more than the fridge could even begin to and we gained some much needed storage space under the cabinet. We can take it along when we travel to a grocery and load our food right into it in the parking lot.
I like the tips for freezing water at home before heading out. We've also used bottled water for this purpose - when it thaws out - drink it.
So far, we've not missed the fridge. Ice is relatively cheap and plentiful on the road. To each his own!
05-04-2014, 07:55 PM
#23
Trailer: 1981 Casita 13. TV: 2011 Honda CR-V
Wisconsin
It appears that there's one main manufacturer of RV iceboxes, so not a lot of pre-made options out there. Contemplating doing an icebox instead of a fridge on our rebuild. Can anyone tell me the internal dimensions of their icebox?
It looks like Scamp and others often use this one:
IB35
But I can't find any info on INTERNAL volume or size. Wondering how much food and ice I can fit in one, but I'd love to get internal dimensions to compare it to one of our coolers.
05-04-2014, 08:05 PM
#24
Trailer: Class A Motorhome
IN LP/120VAC/12VAC Refrigerators there is, at least, Dometic and Norcold. If you look on their respective web sites I believe you will find internal capacities and dimensions.
While the cost of adding a new refrigerator may seem high, it will add substantially to the value and salability of your trailer. There are a lot of buyers out there that won't even consider a trailer without a working refrigerator, and having a newer one is even better.
05-05-2014, 08:27 AM
#25
Trailer: Compact Junior
one problem with ice chests is where to put them....
In my Compact Jr any ice chest on the floor is going to be in the way. And any ice chest that will fit in the small but tall cabinet is going to be tiny.
The option that will work for me is a vertical ice chest. If this link works it will show some of them:
https://www.google.com/search?q=cole...er%3B475%3B685
these are vintage coolers. last fall I bought one of the coleman's with the wood-look door. found it on craigslist.
It has a small footprint but fits into the tall cabinet.
i'll probably add some insulation to the outside walls. I like the idea mentioned here for plastic interior "doors" to help hold the cold in.
05-05-2014, 08:49 AM
#26
Wisconsin
I agree with your points, Bob. BUT, we plan on rebuilding our egg to fit our needs after this camping season. The current fridge is tiny, so it's getting removed in the next month or so and a cooler going in the same opening for now. We'd like to get rid of the huge fridge vents on the side, and aren't planning/worried about resale. So a propane-based fridge is off the table. But I'd like a clean install of something else. Not sure I want to do AC/DC only fridge, still expensive and ALSO would need more battery juice. We find ice to be easy to find, and a well insulated box seems to work very well for our needs. I may end up with AC/DC fridge instead, but we'll see how it goes with just a cooler and ice this season.
05-05-2014, 09:32 AM
#27
Why not gut the old fridge, remove the cooling system, add insulation and make your own icebox. I'm sure you can find a plastic basin that will fit inside to hold the ice. The one thing I would avoid is a drain through the floor. That's just a rotten floor waiting to happen. Raz
05-05-2014, 11:22 AM
#28
Wisconsin
The old fridge is an old Instamatic. It's pretty small, and the door latch isn't awesome, etc.
Our 2 dogs eat raw food, and we tend to eat a fair amount of meat, so we need a decent amount of cooling space.
05-05-2014, 12:07 PM
#29
Perhaps a Coleman extreme cooler might be a better choice.
05-05-2014, 12:16 PM
#30
Trailer: 2010 Scamp 16
I guess different strokes for different folks. I would guess that by not having the cooling system behind the fridge an ice box could in theory be larger capacity by being deeper.
Considering that we have often camped with two coolers, or even a third smaller one I would say ice works. I would think keeping a cooler and adding an ice box might well make sense. Ice will melt faster the more the door is opened. Having one for often accessed items and the other for less accessed items might work out to be an advantage.
There have been folks that added insulation on all sides of the ice box when they installed it and they reported ice block lasting 4 days.
With solar I would think one could make the 110/12 volt compressor type fridge a viable option. Just have to find out the fridge amp draw and figure on it running 1/2 the time or less to get all the amp hours required to be replaced by solar panel.
05-05-2014, 12:55 PM
#31
We use the undercounter fridge for meat and dairy for the humans, coolers for everything else.
Your pups can still eat raw while camping without the need for refrigeration. All you need is water with NRG dehydrated dog food . Easy to store and complies with the rules if you cross borders.
05-05-2014, 01:32 PM
#32
Trailer: 13' Scamp
Your solution
I hear you. This is what I did. I built a super insulated slideout icebox. 1/2 gallon plastic container full of frozen water lasts for about three days unless it is super hot.
The two things I wish for are a drain plug (seemed like a liability at the time I built it), and possible a thermoelectric cooler to augment when I have extra solar power. Also my dimensions were off when I built it and it could have been an inch or two bigger which would have made a difference.
http://www.fiberglassrv.com/forums/f...n-49478-4.html
05-05-2014, 01:40 PM
#33
Trailer: 13' Scamp
With unlimited budget I would get a top loading (drawer) electric compressor fridge, a big solar panel, a cheap light sensor, and a relay. I would run the fridge at a low temperature all day from solar power and then turn it off to save the batteries and also my sanity as I tried to sleep. I would also have a switch to turn it completely off while in storage. Total cost is probably over $1000 mostly driven by the refrigerator (the solar panel is not cheap either). As long as you had sufficient thermal mass (1/2 gallon of milk or OJ) in the fridge I think it would stay very cool over night.
05-05-2014, 01:52 PM
#34
It's highly unusual, but I actually read the "instruction manual" that came with my Coleman Extreme cooler. It says not to drain the water in the cooler ( you're just throwing away the cold ).
But, nothing beats a two-way propane / 120V fridge, in my opinion.
05-05-2014, 01:56 PM
#35
Depends on how cold you want the beer.
05-05-2014, 02:02 PM
#36
Kentucky
lololol
05-05-2014, 06:01 PM
#37
Trailer: Escape 21 - Felicity
Fortunately, when I lived in Germany, I learned to drink warm/room temp beer, tastes better in my opinion. Same with white wine.
Charlie Y
05-05-2014, 06:12 PM
#38
People have camped for years using nothing but coolers. I guess it really depends on your level of comfort and what kind of issues you're willing to deal with.
Frankly, I love the three-way refrigerator in my trailer and my next trailer is getting a bigger one. However, I also carry a cooler for "beverages," so the door to the refrigerator is only opened for food preparation.
05-05-2014, 06:36 PM
#39
Trailer: 2012 Escape 19
Almost anything would beat my 2-way fridge! I'm trying out the new fan inside the fridge today. Temp outside peaked at 92 degrees, currently high 80s. Fridge temp 59 degrees. I don't think the fan is helping.
BTW, the temp bottomed out at 37* overnight (last night), when it was about 60* outside.
05-05-2014, 07:13 PM
#40
Sounds like you fridge might be a bit clogged up inside, reducing circulation and cooling in the cooling circuit.
Two weeks ago, at Joshua Tree National Park, when it was hitting 90+ we were still keeping ice cream hard and beer cold in our 40 y.o. Dometic on gas only.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Which waste water tote and Why?
rabbit |
14 |
07-02-2012 06:26 PM |
Trillium Waste Drain
Terry Jones |
Plumbing | Systems and Fixtures |
6 |
06-06-2009 08:29 AM |
Sending money
Dana T |
4 |
05-16-2009 07:50 PM |
extra money on the road
Sebastian H |
Fulltiming in a Molded Fiberglass Trailer |
5 |
02-05-2008 05:55 PM |
Money troubles?
Legacy Posts |
Jokes, Stories & Tall Tales |
0 |
06-20-2003 12:07 PM |
