Is my rear Trillium window salvageable? - Fiberglass RV
Old 09-23-2011, 09:57 AM   #1
Trailer: 2008 17 ft Casita Spirit Deluxe/'78 Trillium 1300
Arkansas
Before I continue cleaning the awful mess of wood, caulk, glue, dirt and heaven knows what else was left behind when I pulled out the window A/C unit, I need to know if the window is even useable. It looks like a P-PO actually hacked off some of the frame when he removed the emergency hatch to put in the A/C. There are screw holes and missing frame "lips." I really wanted another jalousie but was just going to settle for a fixed window somehow, but I'm not sure I can even do that.
If it's ruined, can anybody suggest an alternative? I really don't want to lose the remaining jalousie, so if someone has an idea what to do with the hole, I would be so, so happy!
Here are some shots of the exterior and interior. Hopefully the hack job is visible. I'm not sure what it's supposed to look like, but I don't think this is it:
Ruth C. is offline   Reply With Quote
Old 09-23-2011, 05:26 PM   #2
Is there enough of a lip to put one piece of glass in there and seal it with glass sealer? I'm cheap, I'd try it....
Old 09-24-2011, 06:30 AM   #3
Joe MacDonald's Avatar
the rear window for that side should actually be a one piece swing out window, for emergency escape. On mine it was hinged at the top, and swung outwards
Joe
Old 09-24-2011, 09:57 AM   #4
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
If you didn't care if the window was operable I would think that a glass shop would be able to make an aluminum framed pane of glass that you could screw into the hole, would probably want to use a sealant around the frame to seal things up. A really clever glass shop would be able to make unit that is top hinged with latches at the bottom for an escape hatch. If your trill doesn't have an escape window probably the po used it for the ac unit and it wouldn't be to hard to put it back to something close to original.
Reid Larsen is offline   Reply With Quote
Old 09-24-2011, 06:55 PM   #5
Trailer: Trillium 4500 1977
Quebec
Before you abandon your old parts, you may consider welding your old frame and fixing it with a simple Dura Fix Aluminum Welding Aluminum Brazing Aluminum Soldering & Repair Rod durafix kit and a propane torch.
Martin J. Qc Canada
lamimartin is offline   Reply With Quote
Old 09-28-2011, 12:20 PM   #6
Roger C H's Avatar
You may want to use safety glass, or plastic, not regular glass.
There is a lot of good information on this site:
http://www.hehrintl.com/index.htm
(Hehr is the brand Trillium now uses.) Apparently, the square corner windows are no longer made, probably because cracks in material with an inside corner will propagate easier from a square corner than a rounded one. There are threads in this blog where persons filled in the corners.
I found interesting that they recommend a gap around the glass.
"Glazing assemblies should be sized for 1/8" to 1/4" clearance between the glazing edge and frame. Use 1/4" setting blocks, made of silicone or polycarbonate- compatible material and wider than glazing thickness."
http://www.hehrintl.com/pdf/HEHR%20GLASS%20CARE.pdf
Old 09-28-2011, 04:24 PM   #7
Quebec
I replaced the door window on my Trillium 4500 because the corner was cracked. It was made of regular 5mm glass (1/4"). I replaced it with an exact copy of the original glass made of clear 5mm polycarbonate (Lexan) which I found at Home Hardware local store. There were spacers around the window to allow for aluminum thermal expansion. I used the best quality of marine (UV resistant) clear silicone I could find.
Polycarbonate is flexible and is practically unbreakable. Cost is much lower than tempered glass and it can be cut with regular carpentry tools. I used a vibrating multi-tool which is safer and easier to use with any plastic than a saber saw EAA Video Player - Your Source for Aviation Videos
Martin J. Qc Canada
trillium
Wanted: 1984 Trillium Rear Emergency Window Jessie, K Classified Archives 0 05-31-2010 08:22 PM
1971 Trillium Rear Window Cracked...help me... Paul Richter Problem Solving | Owners Helping Owners 8 08-11-2009 05:35 PM
Sliding rear window Pat C Problem Solving | Owners Helping Owners 3 05-27-2008 04:35 PM
Where to get new fr/rear window rubber Brian Scott Care and Feeding of Molded Fiberglass Trailers 0 03-03-2008 03:42 PM
Trillium Rear Window Missing David Schroeder Problem Solving | Owners Helping Owners 2 03-17-2007 01:30 PM
