IS OSI the only caulk you can use on fiberglass? - Fiberglass RV
Old 07-04-2016, 09:18 PM   #1
Trailer: in the market
I talked to the Parkliner manager, and he was very amenable to customizing the Parkliner except for the caulk; he said OSI is the only caulk you can use on Fiberglass. Oh, and he also said he had to use a spray adhesive.
So . . . if you've been following my posts, you know that I'm chemically sensitive. I have seen excellent reviews of OSI for durability, but its specs seem to indicate that it's pretty toxic, and that it can cause health problems while still wet, at least.
Is OSI really the only caulk you can use? Can caulk be sealed with a special sealant like AFM that would prevent off gassing?
What I've noticed about campers in general is that when you're in the hot sun, the chemical smells tend to come out more (most campers that are for sale are parked out in the sun, and of course it's summer, so . . . .).
Anyway, do you need the OSI caulk to prevent leaks?
Margaret
Lonely Road is offline   Reply With Quote
Old 07-05-2016, 10:10 AM   #2
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
A lot of folks are recommending butyl tape instead of caulk these days. That's what Little House Customs uses.
Walt
Old 07-05-2016, 11:00 AM   #3
Sounds like Parkliner is not willing to use any other product. I suggest you shop different manufacturers.
Old 07-05-2016, 11:05 AM   #4
Trailer: Casita 17 ft DLX SD
There are lots of other caulks besides OSI but many use the same or similar ingredients. One of the issues with the older / cheaper caulks was that they dried out and became brittle , had poor adhesion to many substrates ,and most required painting to provide UV protection. Modern caulks hold up better ,stretch , are easier to tool , have better adhesion and stay flexible over long time periods , They are chosen because they work well and are relatively inexpensive. I doubt off gassing is even a consideration for most trailer manufacturers / builders. You may well find a caulk / sealant that solves your toxin issues but it may lead to other issues such as a leaking trailer or the caulk requiring constant maintenance.
I would assume that Parkliner uses OSI because it has a proven track record in their application and not lead to leaks / warranty issues.
steve dunham is online now   Reply With Quote
Old 07-05-2016, 11:44 AM   #5
Interesting. I've never even heard of OSI caulk and I've owned an all-molded-towable longer than Parkliner has been in business.
Old 07-05-2016, 11:56 AM   #6
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I've been happy with butyl caulk, Dicor Self Leveling Caulk for horizontal surfaces like vents and other things on the roof, and Geocel ProFlex for everything else. ProFlex comes in clear & white, stays flexible, is paintable, sticks to itself (unlike silicone) and makes great glue.
What ever you use, avoid anything silicone based. It doesn't always stick to fiberglass, will not stick to itself, and leaves a film that is almost impossible to remove when you need to recaulk.
Long-lasting fiberglass caulk? V'sGlassSleeper Problem Solving | Owners Helping Owners 23 03-29-2016 10:15 PM
Can you use some money? Roger C H General Chat 8 11-05-2013 05:16 PM
What Laminate Flooring did you use? Would you use the same brand again? iplumb Modifications, Alterations and Updates 24 01-14-2012 08:30 AM
Do you put caulk under the plastic washer with Scamp rivets? Bryan L. Problem Solving | Owners Helping Owners 1 06-12-2009 11:19 AM
which caulk to use Isaac Problem Solving | Owners Helping Owners 1 06-06-2007 11:31 PM
