Is There a 2 Sided 110 Plug In Out There? - Fiberglass RV
Old 05-01-2011, 06:25 PM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
I want to add a 110 plug in to the outside upper right side of the closet for a small flat screen & am puting the dish reciever on a shelf in the upper inside of the closet & need to have that plugged in. Is there a plug in that's 2 sided so I can plug in the reciever from inside the closet & the tv outside it without having to add a seperate plug? I have called Home Depot & Menards.
barryra is offline   Reply With Quote
Old 05-01-2011, 06:33 PM   #2
Ed Harris's Avatar
Since you really need to install 110 receptacles in a box I would just wire 2 back to back or side by side facing opposite directions to get this done.
Another way I have done this is to make a splice inside an outlet box from the incoming power directly to the 2 cords you need removing the end of them that would plug into an outlet.
I don't encourage doing this but it can work too.
Old 05-01-2011, 11:03 PM   #3
Trailer: Fiber Stream
Question Do you mean Back-to-Back?
Are you thinking about like the way some extension cords have the receptacle end with one socket on one side and 2 sockets on the other?
For a built-in receptacle that has to be mounted in a box, I would say no, I've never seen one.
Old 05-02-2011, 11:42 AM   #4
barryra's Avatar
Thanks Ed & Frederick, I may just jimmy rig something in the closet.
Old 05-02-2011, 12:27 PM   #5
Trailer: 2008 Casita 17 SD
Are you thinking of running an entirely new circuit from your converter or AC distribution box, or tying into an existing 120vac circuit? I would recommend (if you haven't already thought of it,) that you seriously consider installing the first receptacle in the line as a GFCI outlet, for wet location hazard protection. Outdoor outlets need this additional protection, but personally, I think that all trailer outlets should be on a GFCI protected circuit for safety.
Old 05-02-2011, 12:29 PM   #6
Victor Benz's Avatar
Barry;
Use a dougle gang box, and reverse one of the boxes. That will give you a spot for any outlet on either side.
Vic
Victor Benz is offline   Reply With Quote
Old 05-03-2011, 03:34 PM   #7
Chris Z's Avatar
Trailer: 16 Scamp, 17 Casita, 21Bigfoot now
I'm guessing that the wall you are speaking of is very thin. If you were install a plug box with the normal side facing out, I would suspect you could see the box protruding into the closet. On the inside, bring a wire out of the box and let it hang with a female plug on the end of the wire. Not to code so I didn't tell you to do it but I personally wouldn't worry about it. Put a loose knot on the wire inside the box before exiting to the closet so you don't pull on the electrical connection.
Chris Z is offline   Reply With Quote
Old 05-06-2011, 09:18 AM   #8
Mike and Sarah K's Avatar
Trailer: 1979 Trillium 13 ft
New Brunswick
Rather than try to make two boxes with one on either side use 1 box in the closet (out of sight) and make a pass through in the wall like you see on a computer desk or for cables in a house.
Something like this
Pass Through Bundle Wire Wall Plate Single Gang
Mike and Sarah K is offline   Reply With Quote
Old 05-09-2011, 03:02 PM   #9
My suggestion would be to use two 'low profile' recepticle boxes installed back to back.
A low profile box is one half the depth of a regular box.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 05-09-2011, 03:14 PM   #10
IllAnnoy
They make extra shallow plastic non-conductive boxes which could be mounted side by side in the closet with one facing in and one cut through facing out this would give you a normal flush mount on the outside of the cabinet and a surface mount inside. the inside one could be screwed from outside the cabinet using button caps for esthetics, or it could be attached to the shelf inside the closet.
110 Volt Wiring Don N Problem Solving | Owners Helping Owners 31 12-09-2008 01:01 AM
MPG: Egg vs Conventional hard sided TT and Hi-Lo types Kip K. General Chat 16 08-27-2007 07:20 PM
50 amp service with a 110 plug !! Michel pouliot Problem Solving | Owners Helping Owners 6 06-10-2007 06:43 AM
Can 220 be changed to 110? jrnutpaul Problem Solving | Owners Helping Owners 7 02-24-2006 07:42 AM
12 volt and 110 Legacy Posts Problem Solving | Owners Helping Owners 24 07-04-2003 01:41 PM
» Trailer Showcase
Cassie
Karaoke Mike
we-2
lloyd
» Virginia Campgrounds
