is there an outside vent for the stove/range on your trailer? - Fiberglass RV
Old 12-19-2007, 02:40 PM   #1
Ryan Kennelly's Avatar
Trailer: Trillium 4500
So Im going to paint my trailer next month, and I wanted to take out the large home depot looking vent that went behind the fridge''long gone''. this woul clean up the look of the trailer. Not to mention, it would be easier on the spunge when washing... I looked at a bunch of airstreams, and they didnt have a vent behind the stove/ range.
what do you think?
Ryan Kennelly is offline   Reply With Quote
Old 12-19-2007, 02:46 PM   #2
what do you think?
My 2006 Scamp has two vents. A large vent for fridge and a small vent for furnace.
No vent for the cook top, which means that you need to open a couple windows or something have ventilation when cooking. I have a small window over the stove top that I open and I keep the ceiling vent open to some extent all the time.
Old 12-19-2007, 03:09 PM   #3
Same here, I open the window strategically placed over the stove, and crack the roof vent to cook.
Old 12-19-2007, 03:25 PM   #4
I don't have the baggage-door-louvered- looking thing for the stove, but I do have a vent (w/flapper) for the range hood fan.
Old 12-19-2007, 03:30 PM   #5
Trailer: Fiber Stream
Talking
If your fridge is "Long Gone", then the vent has no purpose, and my opinion is that closing up the vent hole is OK.
If you still have a Propane powered fridge, then the vent is necessary and needs to stay.
The new Trilliums are using 12 volt (only) fridges, and not venting them to the outside.
Old 12-19-2007, 04:38 PM   #6
[quote]I don't have the baggage-door-louvered- looking thing for the stove, but I do have a vent (w/flapper) for the range hood fan.
Attachment 11150
Is that little guy up high ''by thr range hood''? or down low,''by the cooktop''?
Old 12-19-2007, 05:12 PM   #7
Gina D.'s Avatar
West Coast USA
They are just behind the range hood, if you have one. Up above the stovetop.
I always forget to secure the flaps on mine. It flops around when driving.
Old 12-19-2007, 07:21 PM   #8
brendadave's Avatar
Trailer: 1976 Trillium 13 ft
Both those vents on the side are for the fridge, whether we run ours on Propane, 12 volt, or 110volt, the fridge gets mighty hot and needs those vents. Of course, no fridge, no problem.
Old 12-19-2007, 07:42 PM   #9
Allrighty then, im takin out the fridge vents! While Im doin mods, What's underneith the bellyband? can I remove it too? As it will interfear with my graphics...
Ryan
Old 12-19-2007, 08:06 PM   #10
Gina D.'s Avatar
West Coast USA
I don't have a belly band, mine is front to back center seam, but...
it's the only seam in your shell. If there is a leak, thats where it will most likely happen (After the usual spots like windows, vents etc)
I don't think I would remove it unless you did some glassing over it to replace the band.
Old 12-19-2007, 10:34 PM   #11
Ofcoarse there would be some glass work to cover all the holes, and then a bunch of sanding to get it to look nice and straight. there is some sort of epoxy holding the 2 halves together, I was just wondering if the band was doing something I didint know about. right now it looks like rubber baby buggy bumpers.
Old 12-19-2007, 11:35 PM   #12
Daniel V.'s Avatar
Trailer: '74 Trillium 1300
I'm fairly new to this, and I don't know how old your trailer is or what your belly band looks like from up close, but I've fixed some leaks along the belly seam on my 1974 Trillium. I did it from the inside, though. There were small metal backplates on the inside, one holding each rivet, that were glued-in under a layer of fiberglass, which covers the entire seam. I had to replace a few of them. It does appear to me that the band's main purpose is to hide the seam, especially where the two gelcoat surfaces do not align perfectly well and where the edges are rough. And, of course, there might be styling. If you care about the Trillium styling, it is possible to polish the aluminium band and replace the entire black rubber molding within the band fairly easily. But if you're trying to do something different and more personalized, I don't see why you couldn't take the whole thing off and grind out any protruding rivet bits and fill the outside part of the seam like they did on the inside. The only possible drawback I can imagine is that if you ever want to sell your Trillium one day, potential buyers / Trillium aficionados might want the belly band where it belongs.
Daniel V. is offline   Reply With Quote
Old 12-20-2007, 04:52 PM   #13
Ed Harris's Avatar
I have had two Trill' and both had some issues regarding the Belly Band.
As is mentioned above there are little metal plates glassed inside that carry a rivet to attach the band.
Of course these plates will rust out leaving both a sagging band and little leaking holes.
I could not figure this out until I yanked the band in spots and dug down inside to really get a good look at the way it is constructed.
I ended up cleaning out the rusted groove as best I could and then using an Epoxy Stick to make the putty I crammed into the seam.
It took a while and you have to work fast as the putty sets up but I was able to lay it down smoothly with a putty knife and in thinlayers to build it up level with the walls.
It stopped the leaking and provided a nice new surface for the band to be re-applied.
I remember seeing an older post with pictures where someone used a similar technique and removed the entire band,worked it smooth and flat and then painted the Trill.
It looked good when he was done and was unique too.
I am sure you can find that post if you search for it.
Good Luck
Ed
Ed Harris is online now   Reply With Quote
Old 12-20-2007, 06:38 PM   #14
me and all my friends love the trill. But it just needs to be modernized a bit. If it weren't for the crazy replacement value of the little guy I would just get new one! but since this one was cheap, I don't have a payment, I can afford to give it some love... So far I've changed the axle,''with a lift kit'' got new alloy wheels, and off-road tires, recovered the cabinet doors, rebuilt the table and got all new hinge hardware. the cushions are at the upholstery shop, the exterior automotive paint just came in, and we will put down some flooring after its all done. things on the list are: a new frame, a cubby hole for the EU2000 Honda gen, and a grey water tank. I also wanna do something cool with the landing gear.
here is an Idea, Since I have all of your attention. what if I had some sort of contest on what the paint job would look like. we would submit drawings or renderings to a post and pic a paint scheme from what was submitted. no real prize other than bragging rights, but might be a fun game. If I get some feedback Ill start a new post and put up the first rendering or two.
Tell me what you think
Ryan
Looking for a used trailer with fridge and stove Robert Johans Wanted: Molded Fiberglass Travel Trailers 4 06-02-2009 05:36 PM
13 Ft Trailer - $2500 Range Tanya Wanted: Molded Fiberglass Travel Trailers 0 07-17-2008 12:30 AM
Range vent hood KamperBob Classified Archives 8 08-30-2007 08:35 AM
Window to replace stove vent PatandBob Problem Solving | Owners Helping Owners 8 08-27-2007 09:54 AM
Thunder Range - Portable Stove Legacy Posts Modifications, Alterations and Updates 3 06-02-2003 10:22 AM
» Trailer Showcase
Scamp
bippygma
bigfoot
karol
