01-03-2018, 12:49 AM
Trailer: ,Retro by Riverside RV
Isolating television interference?
I have a television plugged in to a 110 V outlet in my Casita. I also have a King antenna amplified by my 100v outside plug. When watching tv I have found a visual disturbance when I have an interior light turned on. When the light is turned off the picture is clear. I suspect that I may need to isolate my tv and or
my antenna from the lights. Anyone know what I should do?
Mark
Former Casita owner.
If you have a choice, Please buy, "Made in America"
01-03-2018, 02:11 AM
Mid Left Coast
thats a LED light? you might try wiring a 'bypass capacitor' in parallel across the power to the LED as close to the lamp socket as practical. use a electrolytic capacitor rated 20V or 30V, and as many microfarads as will readily fit in the space available, make sure you get the polarization right (+ lead of capacitor to + wire, - to -). yeah, if you have a lot of LEDs, you'll need a lot of capacitors. or just bypass the ones you'll use while watching TV.
if you move the antenna does the interference change?
01-03-2018, 05:28 AM
Trailer: Casita Independence "Callimachusita"
Ocean City, NJ
A few ideas. https://reductionrevolution.com.au/b...ference-emf-rf
Or you could just get a dollar store battery lamp for while you are watching TV. That’s what I do.
Gordon and Anne
2010 Suzuki Equator "Suzi Q"
2015 Casita Independence "Callimachusita"
Pod Puppies: Josie and Frankie, Casita Kittens: Madison & Razzel & Mrs. Chow
01-03-2018, 06:07 AM
If you take a portable AM radio and go around your trailer, you will find electrical noise everywhere. Each light, your converter, your fan, any charge plugs. Each one contains a switching circuit that produces radio frequency interference. They are like little radio transmitters.
While a bypass capacitor (10 mf parallel with 0.01mf) might help if the noise is coming through the power line, most likely it's propagating through the air. You could try a different model light hoping it produces different harmonics or use a cheap bulb that uses just a resistor to bias the led. (No switcher, no harmonics) . When on shore power, use an incandescent. It will not produce noise but of course will use more power. Everything is a trade off. Good luck, Raz
01-03-2018, 10:36 AM
John, WOW, I just realized how much I don't know about electricity!
And I thought it was going to be an easy fix
Mark
01-03-2018, 10:38 AM
Originally Posted by librarianocnj
Gordan, now that is a solution I can handle. Thanks.
Mark
01-03-2018, 10:43 AM
Raz, so simple, Thanks.
Mark
01-03-2018, 12:46 PM
Trailer: Escape 17 ft Plan B
The easy solution if you want to use the trailer lighting fixtures is to switch to cheap LEDs that don't have a built in voltage regulator. That is the part that usually causes the interference, and it is difficult to eliminate.
If the LEDs that are causing the problem are listed with a voltage range (often 12V - 32V), replace them with a non regulated one, at least near the TV & antenna.
I've used LED panels like these as a replacement for incandescent lamps. Since they are unregulated, they don't cause interference. Even if you burn out one or two, at under $1.00 each, just replace them. You do need to buy as many as you expect you will ever need all at the same time since the batch they come from will likely disappear, and you won't find the same panel (or dealer) the next time you want to order.
01-03-2018, 01:28 PM
raz ham friend of mine suddenly had a huge static noise in his rx. his solution take a small am portable radio and start riding the neighborhood. he found the source a bad pole transformer 1m away!
bob
01-03-2018, 01:38 PM
Use a candle.
01-03-2018, 04:57 PM
Trailer: CASITA
Turn the damned thing off and go out side!
01-03-2018, 05:37 PM
Mid Left Coast
yeah, that. ain't gonna be no telebishun in my camping experiences. ugh.
01-03-2018, 07:58 PM
Trailer: Trail Cruiser
I've been camping for 40 plus years and never even thought of taking a TV with me.
01-30-2018, 12:08 PM
Trailer: 2017 Bigfoot 25B25RQ
Seems like we had the same problem when we had our Casita.
It was an LED light, and maybe the one in the bathroom. Not every light did it, and not on every channel as I recall.
We just got a different trailer. Just kidding of course. I think we just turned off that light and used one that didn't cause the problem.
DeadEyeDan
2017 Bigfoot 25 Rear Bed (25B25RQ), Number Three
2017 RAM 2500 Cummins
02-02-2018, 11:41 PM
Trailer: Trails West
Mark
When my friend installed one of the stick-on LED light strips that had a control for color changing the lights and also dimming the lights he suddenly had a disturbance issue in his boat. It was not the LED lights themselves it is that bells and whistle controller device that is causing the issue.
My best advice, keep it very simple and don't put in dimmer switches. Just set it up so you have options for turning on an extra bulb with its own switch if you need stronger lighting. No fancy color light shows either.
