Jack Nuts - Page 2 - Fiberglass RV
Old 09-01-2013, 09:54 AM   #15
Roy in TO's Avatar
Originally Posted by RRJR View Post
What's a JACK NUT, any pictures of same.and how do they work?
JACK NUT threaded insert
Originally Posted by Thomas G. View Post
No, it is against the forum rules to say anything regarding moderation.
I was always told anything in moderation was less harmful, sometimes it could be good for you.
Old 09-01-2013, 10:19 AM   #16
Trailer: Escape 19
Delaware
Originally Posted by rabbit View Post
Jack nuts require large body hole diameter (7/16" dia. for 1/4" bolt). Require puller. Tendency to spin with corroded or cross threaded bolt and then you got fun. Outer flange sets proud of surface. I consider them light duty junk. The rivnuts for aircraft installation are must more reliable but we always pulled them in epoxy sealer anyway.
jack
Hey,
This ^ rivnuts are a much better option but they too are subject to larger hole, correct installation tool (You can get one that will do 3 sizes of rivnut) highly suggest you epoxy them same as Jack said. If they break loose and spin it is a major PITA to drill them out in fiberglass, if you can't get to the back side. We would use a dental burr on a pencil grinder to grind the head off CAREFULLY. Most of us myself included would put a thin plate of stainless with the appropriate sized hole to fit over the head down first. Then grind so if you slip you do not grind into the fiberglass 15k rpm dental burr makes short work of going through fiberglass. There is another option if you are handy you can use nut plates ( Plate w/ floating nut crimped in place) they use two tiny rivets to hold them in place
http://www.nutplates.com/capped%20info.html. The have them in sealed and open style see http://www.cherryaerospace.com/files...og/CA-1031.pdf for another style mind you using aircraft grade items gets PRICEY.
Cypher
PS Jack in another life were you Air Craft Structural Repair also ?
Cypherian is offline   Reply With Quote
Torque value for wheel nuts Donna D. Towing, Hitching, Axles and Running Gear 28 03-28-2014 05:43 PM
Nuts for camping. Squirrelly McNuts Hi, I am.... 7 04-15-2013 09:27 PM
acorn nuts sfoss Modifications, Alterations and Updates 4 03-03-2012 04:23 PM
Speed Nuts Mike Bromley Care and Feeding of Molded Fiberglass Trailers 5 04-30-2010 08:15 PM
Rivets and Acorn Nuts Steve L. Modifications, Alterations and Updates 6 11-16-2005 08:36 PM
