jalousie window maintenace - Fiberglass RV
Old 08-23-2019, 02:15 PM   #1
Trailer: 1977 Triple E
Hello
I have a 1977 Surfside camper. The jalousie windows do not close tight.
I will add a few pictures'
I need advise, here are a few questions that I have, possibly someone has already worked on their windows?
1) what is the identity of this window
2) the hand crank does not close tight, it seems to not engage in the last turns. I assume the crank needs replacement?
3) will I need to completely remove the window from the camper to clean the window and replace the crank.
Any and all advise appreciated.
Thank you
Bill
William Urie is offline   Reply With Quote
Old 08-23-2019, 02:55 PM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Could it be the operator mechanism? They wear out making operating tough, and are cheap to replace. Both right and left needed.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 08-23-2019, 04:52 PM   #3
John in Michigan's Avatar
Yes the problem is the torque operator. When it wears out, you have to turn the crank several times before the window starts opening, and then when you try to close the window, it appears to be closed, but doesn't actually lock down tight. Driving down the road, my worn out torque operators caused the windows to flap open and closed. Can't be good for the windows, and I replaced the torque operators asap.
As Jim mentioned there is a left version and a right version. To determine the correct torque operator to order, you need to get the model number off the torque operator, or off the window. This may require taking apart the window, or at least removing the torque operator. Our Trillium 4500 jalousie windows are Hehr Series 4900, and for those the model number is on the sill.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 08-23-2019, 04:58 PM   #4
Thank you Jim
where did you get the replacement mechanisms from?
Old 08-23-2019, 05:03 PM   #5
Thank you John
I will look for the model number. to find the number will I need to remove the window from the camper?
Old 08-23-2019, 05:25 PM   #6
Bill, the location of the window model number depends on the window brand and series. For the Hehr Series 4900, the model number is visible on the sill, so no need to remove the window to view it. Not sure about other brands and series.
Old 08-23-2019, 06:06 PM   #7
Originally Posted by William Urie View Post
Thank you Jim
https://interstatervmetalandsupply.c...s-window-parts
Bought all the replacement rubber here too.
2017 Escape 5.0 TA
Old 08-24-2019, 10:13 AM   #8
Jim, thank you. this is very helpful. Bill
Old 08-24-2019, 10:18 AM   #9
John, thank you for this information. Bill
surfside
Jalousie window operator for original Boler window Dave M Problem Solving | Owners Helping Owners 2 05-29-2012 08:33 AM
jalousie window crank repair Roy Massen Problem Solving | Owners Helping Owners 10 06-02-2009 06:37 PM
jalousie window repair Eileen S. Problem Solving | Owners Helping Owners 7 04-14-2008 10:26 PM
Jalousie Window - replace with glass or plexi? Daisy Problem Solving | Owners Helping Owners 7 05-24-2006 04:04 PM
I'm looking for a small jalousie window... Legacy Posts Problem Solving | Owners Helping Owners 3 02-04-2003 08:17 AM
» Trailer Showcase
Alice
Mr.Stu
Scamp
NedMac
