Just purchased a 13ft 81 Scamp ..We have several things to redo - Fiberglass RV
Old 11-25-2013, 01:06 PM   #1
Trailer: 1981 13ft SCAMP
Looking out my window @ what we bought!!
Still happy but .. several litttle things .. we want to do!
We bought her in MO yesterday and pulled it home to Dallas TX took us 14 hours with no problems!
We looked for a small fiberglass unit for about a month..
We are ready to get this party started!
I have seen several post about repairing seams
Is the home improvement store stock flexable vinyl molding best to redo seams? ( the original tape is discolored and missing in spots)
I wonder how hard or how costly to replace our side windows?
Can we maybe add a larger windows similar to the one in the front & back?
Can the body be cut out to put a larger windows in?
what type of issues? if we do install larger ones?
Seems this year scamp must have come with and has a square shape aluminum frame windows along sides with oblong vinyl / rubber edged ones in front and back? I would like the larger style windows all the way around?
CAROLPHAYES is offline   Reply With Quote
Old 11-25-2013, 02:06 PM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Welcome to the site.
Congrats on your purchase, lots of good times to be had with your new to you trailer.
BTW, time to change your user info now too.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 11-25-2013, 02:24 PM   #3
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Carol, congratulations on your find. We are on our 2nd 13' Scamp and love them. Our front and rear rubber mounted windows were plexiglass on our 1984, but our 1990 rear window is an aluminum slider. The fiberglass is molded differently from our 1st, as it is molded to have a flat surface for the flat aluminum frame, and the 1st plexiglass window curved to fit the curve of the fiberglass. Unless yours is molded for the flat surface, or unless you plan to rework it to a flat surface, you'll have to stay with the original. The side windows can be enlarged somewhat, but remember that the fiberglass IS the structure to hold up the roof, so don't over do it. Scamp still sells the seam tape to replace the missing or yellowed tape. Some here on the forum have removed the tape and filled the seam gaps with flexible/paintable calking that had been textured with a wet paper towel or rag while it was still curing, then they painted all the ensolite. Good luck with your personalizing touches, and Happy Trails
Dave & Paula
Old 11-25-2013, 03:03 PM   #4
Trailer: 2010 Escape 17B
Welcome, great find and you towed it quite the distance with no problems!
If you get the seam tape from Scamp just remember to add extra strong adhesive as the stuff it comes with does not last long, otherwise I quite liked it when I used it and it is very reasonably priced. They have lots of other bits and pieces too.
Scamp Trailers Parts Store
kootenaigirl is online now   Reply With Quote
Old 11-25-2013, 04:11 PM   #5
Completed the profile update!
I tried to update that earlier and it never accepted my new values .. seems the server was timing out...
Old 11-25-2013, 04:59 PM   #6
I like the idea of flexable caulk and texturing that... and then paint!
We have gotten very good a caulking!
Old 11-25-2013, 05:09 PM   #7
Ms. Gayle's Avatar
Trailer: 2010 EggCamper #85
Midwest
Carol,
I think I might have talked to you at a gas station. Is you Scamp the one that had about 50 bumper stickers on the back?
Ms. Gayle 2010 EggCamper (Purchased April 2012)
2012-IA,MO,NE,WY,MT,UT,NM,AZ,TX/2013-AR, LA, AL, FL, GA, SC, NC, TN, KY, KS, CO/2014-FL,MO,MN,MI,WI IA/2015-SD,IA,MO,OK,TX/2016-AR,MS,FL,MO,IN,VA,NC,TN/2017-KS,CO,UT,AR,MS,FL
Ms. Gayle is online now   Reply With Quote
Old 11-25-2013, 05:35 PM   #8
Yep..Ms. gayle.. I remember you!
We are so excited about this new project!
Where were we when we spoke?... As the drive home it was about getting home before the winter storm hit .. and we beat it into Texas..
Thank goodness we made it no problems!
We just purchased a 2004 13' scamp---13' vs 16' Chuck n Julie General Chat 21 02-27-2013 11:57 AM
What's the best way to fastened things inside my Scamp Jay Marlette Problem Solving | Owners Helping Owners 14 11-03-2012 02:56 PM
81 Scamp just purchased Piscator Hi, I am.... 16 04-17-2011 05:30 PM
Things out of my Scamp 13 troy c Classified Archives 7 11-04-2010 06:30 PM
