Kumho 857 Tire Discontinued Canada?? Souce for Aluminum Rims - Fiberglass RV
Old 07-16-2013, 11:28 PM   #1
Rusty99's Avatar
Trailer: 1972 & 1978 Bolers 13ft
Hi Folks,
I've been reading a few posts about how great the Kumho 857 tire is to put on Boler trailers and was super excited to get some.
Using the Kumho Canada website I called a local OK Tire shop and was told that the Kumho 857 was no longer available as it was discontinued?
Is this true? I live in Edmonton and would like to get my hands on 3 tires.
Also I'm looking for a really nice set of Aluminum Rims for my boler. I'm looking to get something really fancy and flashy. I've been advised a 14 inch or 15 Rim with a zero offset is what I should be looking for.
Any places online or in Edmonton Area that you can suggest me to start looking? The small 14 and 15 rims are hard to come by and not much selection from what I've seen so far.
Cheers
Rusty
Rusty99 is offline   Reply With Quote
Old 07-17-2013, 07:05 AM   #2
Trailer: '78 Trillium 4500
I couldn't find Kumho's in Canada either, but they seem to be available readily in the US. I did find Maxxis m8008s which I have used in the past and have been quite happy with.
Kal-tire carries some wheels, depends on how much you want to spend. Most tire shops have access to most wheel styles/brands, but you'll do better if you do your research on the web before you go in and give them the style/part number.
Dave_L is offline   Reply With Quote
Old 07-17-2013, 07:09 AM   #3
Trailer: 2008 Casita 17 SD
If you should decide on aluminum rims, be sure to get the appropriate lug nuts for them as well. Aluminum rim lug nuts are different than their steel rim counterparts, and they are not cross-compatible.
Old 07-17-2013, 07:18 AM   #4
Trailer: FunFinder
Does Tirerack ship to Canada ? Or is there some import duty cost penalty that makes it too expensive ?
As for wheels, check out the Sendel wheels site.
gmw photos is offline   Reply With Quote
Old 07-17-2013, 08:22 AM   #5
Greg, what is the difference in lug nuts?
Old 07-17-2013, 09:50 AM   #6
Trailer: FunFinder
Here's a bit of info on lug nuts/bolts:
http://www.tirerack.com/wheels/tech/...8-a756c1f7efc4
I believe that all the Sendel aluminum trailer wheels are a standard 60 degree conical taper. I know mine are, because I swapped the OE stainless "clad" nuts for aftermarket chrome ( not clad ).
Old 07-17-2013, 10:42 AM   #7
Paragraph copied from the website at the above link... (first two sentences describe what I was referring to.) Not all aluminum and alloy wheels require them, but there are many out there which do. Just be sure to check compatibility to be safe.
"While many aftermarket alloy wheels are designed to use your car's original lug nuts or bolts, others require new hardware. It may be something as critical as differences in the wheel's lug seat design as shown below, or something as simple as shorter lug heads to allow the wheel's center caps to fit. If your new wheels require new hardware, your invoice will list the appropriate quantity identified by our part description, beginning with an "N" for lug nuts or a "B" for lug bolts followed by the size, pitch, seat design, length and the appropriate lug wrench socket size."
Old 07-17-2013, 11:29 AM   #8
Some are, some aren't compatible. Most lug nuts are 60 degree taper and could/should work depending on the age. Some wheels require a narrow or tall lug nut to fit, best to check first with what you have, as blanket statements can be misleading.
Old 07-17-2013, 02:22 PM   #9
David Tilston's Avatar
Here is a good blanket statment: Make sure your lug nuts are tight enough.
Almost lost a wheel
Old 07-17-2013, 02:54 PM   #10
yup, common sense that one.
4 on 4 rims Willard L Problem Solving | Owners Helping Owners 13 08-19-2012 10:32 PM
the Coleman battery powered camp shower: discontinued! jen b General Chat 2 03-16-2011 01:40 PM
Aluminum Rims in Canada? Dave_L Towing, Hitching, Axles and Running Gear 14 09-04-2009 02:04 PM
Tire Options? (in Canada) David Swinnard Towing, Hitching, Axles and Running Gear 15 05-23-2008 04:01 PM
