Laminate flooring trim - Page 2 - Fiberglass RV
Old 07-14-2007, 06:36 PM   #15
Trailer: 2007 Bigfoot 25b25rq
I used wood tone caulk and it looked good enough that I left it without trim. You should caulk anyway before you put down trim just to seal the edges in case of a big spill. See what you think after caulking, then add trim if desired. Most of my caulked edges aren't visible under the counters anyhow.
Derek
Derek Johnson is offline   Reply With Quote
New Flooring-Laminate or Vinyl Tim Wood Care and Feeding of Molded Fiberglass Trailers 49 03-08-2015 03:11 PM
Flooring trim solution.. cheap and easy! Gina D. Modifications, Alterations and Updates 15 08-24-2009 11:54 PM
Microwave build in and laminate floor Karen K. Modifications, Alterations and Updates 9 01-20-2008 02:42 PM
carpet vs laminate Al & Donna Modifications, Alterations and Updates 37 03-18-2007 11:12 PM
Laminate Flooring Chris Seddon Modifications, Alterations and Updates 5 05-17-2006 11:31 PM
