Last little thing - a freshwater leak - Fiberglass RV
Old 07-20-2008, 11:34 PM   #1
JenPB's Avatar
Trailer: 1972 Compact Jr
Thumbs up
When we brought home Junior ('72 Compact Jr.) there was a water tank with NO hoses or fittings. I've been trying to put this thing together and FINALLY got all the proper fittings (as proper as possible given no one HAD a hose or fitting that would work with existing tank). I have a tiny bit of leak still on the fill end.
To make it all work I:
- replaced outside filler inlet to match moder standard hose diameters
- carved out old filler neck from tank (NO matching hoses available short unsuitable shrink tubing)
- used hole saw to expand tank hole for compression fitting
- install new neck with compression (plumbers) fitting
- connect tank to filler with modern day flexible hose.
- Watch it leak during first fill
- remove hose
-wrap both fitting ends with teflon tape
- press on new hose
- watch dry fill! WOO HOO!
- Travel 50 miles down the road
- Open TT only to find there's still a relatively minor leak at the fitting/tank connection)
My question, given that the hose is tight and the fitting is as expanded (tight) as it will get: if I use silicone around the base of the fitting (where the water leaks as it splashes about inside the tank on the road), will it hold with all the jiggling the trailer gets?
Jen
"Nowhere to be and all day to get there." - The Bills
JenPB is offline   Reply With Quote
Old 07-21-2008, 05:26 AM   #2
Steve L.'s Avatar
I'm not confident that the hose would stay on over bumpy roads. Why not a couple hose clamps at each end? I like the stainless steel hose clamps, often available at your average home center. Probably not more than $2.00 each.
Without adult supervision...
Also,
Old 07-21-2008, 11:14 AM   #3
JenPB's Avatar
Thanks, Steve, I'm not so confident either. Hose clamps going on today.
How about the base leak? To silicon or not to silicon...
Jen in Cal
6 days and counting!
Jen
I did a dumb thing! Jason Rutten Problem Solving | Owners Helping Owners 0 05-05-2010 09:03 AM
Fiberglass is one thing but ronsmith100 General Chat 7 08-07-2009 08:39 PM
What is the one thing (or two or three) that you cannot live without? Monica M Fulltiming in a Molded Fiberglass Trailer 43 04-16-2009 01:48 PM
Can I lock this thing??? Lynn L General Chat 13 06-09-2008 02:33 PM
The VERY next thing! Roger H General Chat 12 11-25-2005 11:27 PM
