Leak at seam? - Fiberglass RV
Old 07-24-2014, 12:00 PM   #1
Trailer: 1976 Boler 13 ft
Leak at seam?
I have a leak below the corner of my rear non opening window (76 boler). It seems to be right behind or near the middle seam so im assuming that it's a rivet. How do i fix this? I'm thinking (hoping) that i just need to replace the rivet that's there and add some caulking to it. Thanks
cyndi H is offline   Reply With Quote
Old 07-24-2014, 12:09 PM   #2
Roy in TO's Avatar
Sometimes the rubber gasket shrinks a bit over the years and you get a small gap. It might be what you call the middle seam. If that is the case, you can replace the window gasket. I've been able to simply fill the gap with some flexible putty to stop the small leak.
Old 07-24-2014, 12:26 PM   #3
Would the gap be easily visible with the eye? The water is near seam (middle horizontal belly band where top/bottom meet) so i assumed it was coming from there. Around the window and window seams is dry. Could it be entering at window and running down? i thought more likely to be rivet. I guess i'll have to test spray it
Old 07-24-2014, 02:04 PM   #4
Borrego Dave's Avatar
Can you post a pic of it ?
Roof Seam Leak? melissab General Chat 4 05-15-2011 08:24 PM
Rubber roof leak at seam Cngdad General Chat 4 02-26-2011 09:29 PM
Compact Jr Exterior Seam Tape Sharyl Allender Care and Feeding of Molded Fiberglass Trailers 2 07-16-2009 12:00 AM
Seam tape glue removal Steve Smith Problem Solving | Owners Helping Owners 4 06-27-2009 10:37 PM
Need source for exterior metal seam on '73 Love Bug Christopher Singer Care and Feeding of Molded Fiberglass Trailers 5 06-02-2009 11:55 AM
